engine backfire.
engine backfire.
Hello,
I get a backfire in the exh. when i rev it and let off or if I bring the rpms up to like 3500 when shifting. Just one pop when I let off the gas. seems worse when engine is not warmed up. Also get a vibration when under load or when driving at 1500 or so rpms. The vibration is not as bad if I drop a gear and bring the rpms up. feels like something in the drive train. any thoughts?? It is a 305 tpi 5 spd.
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
could you please explain? i've got some issue where the car runs fine as long as i set the idle to 900 or higher. sometimes it will idle ok at 800 but most of the time the rpms jump around and it wants to die when it gets under about 850. i've just left the idle at 900 when in gear and about 1150 in park and it runs fine but i'd like to idle about 650 or 7. sound like a vacuum problem?
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Here is something real quick to check. Dead cyl. Pull the connector off one injector at a time and see if you don't get a simular result with one of them. Would indicate a bad injector or bad plug or bad plug wire. I know you changed plugs and wires but I have seen brand new ones fail right out of the box.
Car: '86 Berlinetta
to check for a vacuum leak you turn the car on, pop the hood. Then take some carb cleaner and spray it around the engine bay. When the car acts different (might bog, or rev higher) when you spray it in a certain area then you have determined the general area of your vacuum leak
any way to do it without getting carb cleaner all over my engine? lol
Any other ideas???
