New oil pump. Is high volume better?
Old Apr 21, 2005 | 09:40 AM
csi1286's Avatar
Car: 91 Camaro RS white w/ T-tops
Engine: original 305TBI 140,000mi
Transmission: automatic (although standard would be preffered)
I have 305 TBI I'm looking for a new oil pump and im curious whether a high volume pump is better or if it would be bad to put in a stock 305 TBI engine.
-thanks
Old Apr 21, 2005 | 09:55 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
A high volume pump takes more power to turn. With a stock engine I would go with stock replacement pump.
Old Apr 21, 2005 | 10:42 AM
csi1286's Avatar
Thanks.
Old Apr 21, 2005 | 11:15 AM
ede's Avatar
ede
stock volumn M55 with mr gasket #26 spring
Old Apr 21, 2005 | 04:44 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Do I Understand correctly... having the stock pump moves the same amount of oil regardless, but the #26 springs bypasses at a higher pressure, giving more pressure at higher rpms?
What kind of pressure would the stock M55 give at say 5k-6k rpms? What kind of pressure with the #26 spring at the same rpms? What about around idle?
Old Apr 21, 2005 | 06:08 PM
ede's Avatar
ede
all i ever used pegged the gauge cold and would run 50psi hot, more or less
Old Apr 21, 2005 | 08:34 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
not to mention a high volume pump will suck a stock pan dry.
Old Apr 21, 2005 | 10:18 PM
sellmanb's Avatar
Car: '86 Berlinetta
The "ultimate" combo that I've seen floating around here (and I've done it ) is the Melling M-55 oil pump, the High Volume M-55A Oil Pump Pickup, and the Mr. Gasket #26 spring.
This way you have the ability to suck up more oil than you might need, but just incase... and you're squirting the oil at a high pressure, yet still volume, which is a good thing in your case
Old Apr 22, 2005 | 11:20 AM
leeski's Avatar
Car: '82 Berlinnetta
Engine: Modified 350
Transmission: Turbo 350
I don't meen to hijack this thread but I made the mistake of using a high volume pump and it indeed runs the pan dry if the motor is held wfo for too long ('bout crapped myself the first time I saw it). Are there any 6 or 7 quart pans that work well for our cars?
Old Apr 22, 2005 | 02:25 PM
Engine: LB9/383
I posted that a couple replies up.
I think it's Moroso that makes a nice pan for the thirdgens in a 7 qt. version. I've got a local guy around here that does them too.
Old Apr 22, 2005 | 02:36 PM
leeski's Avatar
how much $ for a pan from your local dude?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
