A bit lean perhaps??
Old Aug 6, 2001 | 09:48 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Well my car has been running a bit on the warm side lately despite a new water pump and an aluminum radiator. Also I have straight tips that run out the back and I don't see any carbon on them anymore, there used to be some on there before after a few days. I changed my O2 sensor last year and I changed my fuel pump just over a year ago. So, I'm not sure what else would caused a lean condition. Any other tests or suggestions?
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Aug 7, 2001 | 11:07 PM
Car: 92' RS
Engine: LO3
Come on, any ideas?
Old Aug 8, 2001 | 02:18 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Vacuum leaks can cause a lean condition (not sure with SD systems, but definatly MAF), is your fan working OK? Is the bottom radiator hose collapsing under throttle? Is your lower air deflector missing? T-Stat working OK?
The O2 sensor should correct for a lean in part throttle driving.
Also, a bad CTS could be the culprit, but still I think this would set a code.
Mark_ZZ3
May 24, 2018 01:02 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
drumstixer
Sep 29, 2015 03:02 PM
Marc Brown
Sep 28, 2015 01:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
