permatex sealant for head bolts
Old Apr 25, 2005 | 02:58 PM
Cole's Avatar
I've searched and it looks like permatex sealant with teflon is the popular choice for sealing head bolts. The problem is, I'm finding that they make a few different types of thread sealant. I have a tube of "Thread sealant w/ teflon" 14AR (80631) and type 2 already, and have seen "High performance thread sealant" (part 25117 and 56521 depending on container size) and "high temperature thread sealant" (59214 and 59235). Should I use one of the sealants that I have, or buy one of the others? Thanks.
Old Apr 25, 2005 | 03:55 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Why are you sealing head bolts? What motor are you building?
Old Apr 25, 2005 | 05:21 PM
Cole's Avatar
because they thread into the water jacket. I'm working on an LG4 305.
Old Apr 25, 2005 | 05:37 PM
Engine: tpi 305
Your right as I think of it. I've built lots of motors and never sealed head bolts before, though. Just globbed the threads with STP and thrown them in. Never seen any probs either. Just lucky, I suppose. Guess I'd better think of that from now on, huh?
Old Apr 25, 2005 | 05:48 PM
Cole's Avatar
Ha ha. I would recommend it.
Old Apr 25, 2005 | 06:50 PM
littlekings's Avatar
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
I'm putting one together right now, I used red permatex, seems to work fine.
Old Apr 25, 2005 | 09:14 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Built many motors using Permatex #2. No problems. But in the last few years I've switched to the Permatex thread sealant with teflon.. Small tube, white goo. .Not sure of the # but have had no problems with it either.
Learned the hard way back in 86 that the bolts had to be sealed. Had water in the oil of my 396 and couldnt figure out where it was coming from.. Sealed the bolts no more problem.
Old Apr 26, 2005 | 05:05 AM
ede's Avatar
ede
any non hardening sealer will work, like you said teflon sealer is popular
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
