Oil pans
Old Apr 26, 2005 | 09:51 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
Oil pans
Since when did they start using aluminum oil pan on full size vans? I'm working on a 98 express van that through a rod through the oil pan and I was suprised to see that it was aluminum. I thought the LSx series of motors got those oil pans.
Old Apr 27, 2005 | 01:34 AM
Vader's Avatar
Around '96 when the "Vortec" engines started replacing the "regular" SBCs in trucks. The Vortec V-6 engines may have had them sooner. Most all of them have cast aluminum pans now for added case rigidity. Moreover, the transmission bolts into the pan in two places on some models. to help hold it all together.
This going into a ThirdGen?
Old Apr 27, 2005 | 09:39 PM
Car: 91 camaro rs
Engine: 350tpi
It's kind of funny you mentioned Vortec V6 because that's exactly what it is. I didn't look under the hood because I didn't have time last night and this morning I looked under the hood to figure out what is in there. Imagine my surprise to find out that this 3/4 ton van has a 6 cylinder. I found a 95 S10 at a junkyard that doesn't have an aluminum oil pan, but it's still a Vortec V6. I guess they must have started the aluminum oil pan thing later. Probably did it when they changed body styles.
This won't be going in my car. I already have a 350 with those crappy TBI heads on it. I just recently put a quick ring job on it and had the heads cheaply done. I reused the pistons and bearings. I figure I'll get 30,000 miles out of it if not more. When I get it bored with new pistons and bearings I'll find a better set of heads. Until I do all that I'm just gonna drive it.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
