Spark Plug Wire Question
Old Apr 28, 2005 | 10:24 PM
LiquidSnake's Avatar
Car: 1989 Camaro RS
Engine: L03 V8 305cid
Transmission: Borg Warner T-5
So the other night I changed the plugs and wires on my car and I thought I hooked them up the same way I took them off but when I took it out for a test drive the car sounded good but under pretty much any acceration the performance was horrible... with very little actual acceration so I checked out the Chiltons manual and it said all the wires were hooked up to the wrong cylinders which I thought was odd... but I switched em around anyway So after that I tried to start the car and it cranks obviously enough but when it fires the engine makes a noise and just keeps cranking... If someone knows how to hook up the wires for an L03 (TBI 305) any help would be GREAT. Thanks in advance...
Old Apr 28, 2005 | 10:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<img src="https://www.thirdgen.org/techbb2/attachment.php?s=&postid=2138965">
Old Apr 28, 2005 | 11:19 PM
Car: 1989 Camaro RS
Thats how I have it hooked up I double checked it and I just tried starting again and it shot fuel out of the throttle body! (this time I tried it with the air cleaner assy off)
Old Apr 28, 2005 | 11:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How were they on before?
Old Apr 28, 2005 | 11:34 PM
Car: 1989 Camaro RS
I dont remember
Old Apr 29, 2005 | 12:29 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
one thing I can think of is maybe someone was playing with the dizzy and had the wires in the same spot but moved one post left or one post right
Old Apr 29, 2005 | 12:33 AM
Car: 1989 Camaro RS
hmmm that sounds possible... I guess i'll go try it... if that is the case would you be able to tell me how to fix it?
Old Apr 29, 2005 | 12:51 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Crank the engine over by hand to #1 TDC, take the cap off and look where the rotor is pointing. The terminal it's pointing to is the #1 terminal, maybe the #6 if you don't get the firing stroke right.
Car: 1989 Camaro RS
moved them all one post to the right...got the same thing
moved them all one post to the left... and it almost seemed like the engine wanted to fire up...it didnt spit anything out of the throttle body...have I at least taken a step in the right direction?
Old Apr 29, 2005 | 12:52 AM
Car: 1989 Camaro RS
how do I determine when cyl #1 is at TDC?
Old Apr 29, 2005 | 12:59 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Look at the timing marks on the balancer behind the waterpump.
Old Apr 29, 2005 | 01:02 AM
Car: 1989 Camaro RS
groovy...thanks unfortunately I will have to wait until the weekend though
Old Apr 29, 2005 | 01:06 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
To make sure you've got the firing stroke on #1, you can pull the #1 plug out and hold your finger over the hole as you crank it. If you feel compression while it nears the top, then you're on the firing stroke. If not, you're on the #6 firing stroke.
Old Apr 29, 2005 | 01:07 AM
Car: 1989 Camaro RS
I see and I imagine I just keep crankin till i feel compression to get to the #1 firing stroke correct?
Old Apr 29, 2005 | 01:33 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right, take the other plugs out so that you're night fighting their compression while you turn the engine. You can either bump it over carefully with the starter, or you can turn it by hand.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
djmarch
Aug 9, 2015 05:27 PM
