What kind of cam are you guys running?
Old Apr 29, 2005 | 01:36 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
For those of you with aftermarket cams - what duration at 050, LSA and max. lift are you running? How do you liike it?
I have a stock 350 cam and want to get something maybe in the 218/230 range. I've got a 3000 stall and 3.73 gears.
Why did you choose your cam and how is it working for you? - how much power are you getting, how bad(or good) is idle, and is mileage realy suffering? Thanks.
Old Apr 29, 2005 | 02:35 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
230/244 .544 .574 112 LSA @ 0.050 lift
Was in my 350 and loved it, plenty streetable and breaks were good, still had 13 lb's of vacuum.
Its now going in my new 383 .
Old Apr 29, 2005 | 03:47 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
230/236 @ 0.050, .544"/.555", 110 LSA (hyd. roller) in a 355
Mileage sucks, brakes are ok, idle sucks. Im running a 3500 stall, so I dont notice any lack of low end, but the top end is pretty insane. No dyno numbers yet.
Truthfully, if I could do it over again and I wanted a cam this size or bigger, I would have put in a solid roller.
Old Apr 29, 2005 | 04:30 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Identical cam, but my idle doesn't suck (800RPM). Behind a 5-speed with 4.11's and the top end power is definitely INSANE .
Old Apr 29, 2005 | 10:02 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Mine is the edelbrock performer rpm 234/238 and 539/548 and is a hyd roller. Im putting it in tommorow. Supposed to be a choppy idle and make power from 1,500-6,500 and my car has 3.73's and a 5speed. We are all running similar cam specs.
Old Apr 29, 2005 | 10:13 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Wow, lots of testosterone here !
My cam... 222/222 .467/.467 @ .050 (110 LSA). Idles nice
at slightly higher 800 rpm. But still, went 12.88 with it
due to good traction (1.79 60 ft).
Old Apr 29, 2005 | 10:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
My 383 had a flat hydraulic 224/230 .477/.480 110, but it ate itself when the oil pump died. I'll be probably be using a 236/242 .520/.540 110 hydraulic roller when it goes back together.
Old Apr 29, 2005 | 10:59 PM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
Streetable? Cool.
Good to read that. I have Roostmeyer's old cam (XE276HR) and was wondering how it would be with AFRs and either an LT1 or an HSR. I know it takes tuning, but knowing larger cams aren't killing manners altogether makes for peace of mind....
K
Old Apr 30, 2005 | 07:28 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
227/233 112 LSA, 109 ICL .560/.569... Its a custom cam from Combination motorsports...
Old Apr 30, 2005 | 03:12 PM
mdricken's Avatar
Car: 92 Camaro
What would solid roller do for ya? Just more lift? I assume you already are using a roller, not flat tappet.
Old Apr 30, 2005 | 03:40 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Guess I'm the oddball guy of the group. I bought my cam with TPI in mind.
Lingelfetler 74211 cam.
211/219 @.050" duration
.530/.560" lift w/1.6rr's
112* lobe sep
installed straight up.
Seems to be doing okay, no tune on the car yet, and the plugs are just a tad fouled. Pull's way harder up top then down low (odd, but I think its so rich down low that it responds very slugishly.) Hangs with LT1's up top on the highway from 80mph rolls to about 140 or 150mph.
Hung with an LT1/M6 w/hooker cat-back all the way through 3rd gear till I let off because I was turning 5,700rpm.
So I'm happy for now, can't wait to get it tuned.
Old Apr 30, 2005 | 03:51 PM
brutalform's Avatar
Got a small solid roller. 236/242@.050
Old Apr 30, 2005 | 04:03 PM
klumb15's Avatar
XE276HR for me, .503/.510 lift with 1.6 roller rockers, 224/230 duration with HSR intake on a 350....haven't put the motor in yet tho...ran into a few roadblocks...from what i understand it is a great street cam, not to lumpy, but more than enough umph...
Old Apr 30, 2005 | 06:59 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
More lift, yes...and a lighter valvetrain, more aggressive ramps, and more rpm potential.
Also, to avoid ~5000rpm valve float, I could only use about 1/4 turn past zero lash on the (Comp-R) lifter preload. This seems loose enough to worry me, so I check it regularly...and this pretty much nullifies the main advantage of the hyd. roller.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
86IROC112
Aug 17, 2015 02:00 PM
