Second Starter in a Year?
Old Apr 29, 2005 | 11:17 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Is this common?
My starter is doing the "click" thing. I replaced the solenoid last year less than 4K miles ago.
I suppose it is to be expeted that this would happen since I drive very short trips many times a week but under a year? Cmon!
Old Apr 30, 2005 | 02:06 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
hey i got a mini torque starter that has 2hp from ebaymotors ill give you the guy its an awesome setup infact you dont even have to drop your exhaust to remove it :-D
sometimes its just a tap of the starter and she fires
only paid $99 and it has a lifetime warranty
Old Apr 30, 2005 | 09:42 AM
Cadillac's Avatar
Wel dayum! Thanks Eric.
So the clicking is the starter, right? Not the solenoid?
Old May 3, 2005 | 12:41 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
on my mazda I had a problem with a small click and then a weird high pitched (like a tv left on mute ) noise or it would stick in the keep trying to start stage
all that was wrong with it was the selenoid was sticking
took it apart sprayed it down with WD-40 and then wiped it dry as I can and it worked since
mhatfield 14
Oct 24, 2015 07:48 AM
5spdcamaro
Aug 28, 2015 02:12 AM
Cleotiz
Aug 22, 2015 01:54 PM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
