Clunking sound in driveshaft when i accelerate?
Old Aug 10, 2001 | 11:43 PM
89Firebird Formula350's Avatar
Whenever I get on the pedal and start to accelerate, there is a clunk noise, which seems to be in the drive shaft. Do you know what this could be? Thanks in advance!
Old Aug 11, 2001 | 12:05 AM
Guest
Guest
Posts: n/a
Sounds like a busted tranny mount. Relatively simple fix. Find someone who carries the rectangular shaped one if you want a rubber mount, it used to be listed under mid 80's Monte Carlos, its a much stronger mount and bolts right in.
[This message has been edited by madmax (edited August 10, 2001).]
Old Aug 11, 2001 | 12:33 AM
Gta-Paladin's Avatar
yes i'd prescribe a broken tranny mount aswell... just get a poly one... I replaced mine with a stock one and it's broken again...
Old Aug 11, 2001 | 12:36 AM
Thanks MadMax that helped me kinda find out what was wrong. My car is an 89 Firebird Formula 350, is that what you think is wrong?
Thanks!
Old Aug 11, 2001 | 12:50 AM
TransAm4u2race's Avatar
check the torque arm bushing too. Mine went bad in my 84 TA Does it sometimes make a clunking sound when u put it in gear? if so id check the torque arm bushing
Old Aug 11, 2001 | 12:59 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
U-joint maybe??
Old Aug 11, 2001 | 02:17 AM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
my 84 t/a does the same da** thing, but i dont know what it is. could it be the torque arm?
Old Aug 11, 2001 | 08:00 AM
El Guapo's Avatar
Order of probability:
1) Tranny mount
2) Tranny mount
3) Tranny mount
4) Torque arm bushing
5) Voices in your head
6) Voices from outerspace
7) Voices in my head
8) Your car's Voice
The clunking sounds when you accelerate is a classic for the tranny mount being busted. Regardless of the year and motor of the vehicle. My old 89 2.8 made that sound. My friends 77 Chevy pickup made that sound. My advice would be to get the car in the air, pull the mount and see if its busted. If it is borrow someones vehicle and get one. then replace it.
I would recommend that you go buy the part, but seeing as how youre not taking anybodys advice, check it for yourself then go get the part.
Clayton
Old Aug 11, 2001 | 10:06 AM
Thanks everybody, that really helped me out! I really appreciate your info! Thanks again!
Old Aug 11, 2001 | 06:08 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I had a similar problem with my car, I thought it was coming from the rear end or the rear of the drive shaft. I had the fluid in my Posi Rear change, and it went away. The Mechanic told me that when the fluid breaks down in these rears, it will do that. He said it was important to put the posi additives back in the rear. It was a pretty bad noise. I thought the friggin rear was on it's way out for sure, but it is perfect now, and has been for about 2 months.
Later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
amcnellis
Sep 16, 2015 04:16 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Ragtop Man
Sep 12, 2015 12:23 AM
