Front suspension rebuild: stuck bolt
Old Aug 6, 2001 | 10:00 PM
iroc5speed's Avatar
I am rebuiding my front suspension with a polygraphite kit from PST. I have taken off every bolt needed to get the control arm (A arm) off. One bolt decided to stick though, and I can't seem to get it out of the arm/frame. I got the nut off, but the bolt won't slide through. please help.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 6, 2001 | 10:07 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm guessing you mean one of the inner bolts. I beat mine out with a ball peen hammer. If for some reason you damage the threads doing this you can always replace it.
Old Aug 6, 2001 | 10:10 PM
iroc5speed's Avatar
I tried beating it out with a hammer, but it dodn't want to budge, and it is a bit of a tight space, you are correct it is an inner bolt, where the control arm connects to the frame.
Old Aug 8, 2001 | 09:39 PM
iroc5speed's Avatar
has anyone else rebuilt their suspensions here and encountered this problem?
Old Aug 8, 2001 | 10:24 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Yup I have
Put a socket on it and screw it outta there.
If that doesnt work get a open end 18mm, put it on the head of the bolt, grab the end of the wrench and pull it straight towards ya turning it back and forth.
Beleive me I know it all too well.. I've had my front end apart on my car about 4 times in a year
Kat
Old Aug 8, 2001 | 11:13 PM
maksik7's Avatar
This happened to me, one of the bolts on my rear supsension was REALLY tight. After toying with attaching little pipes to the wrench for more torque (bent them all) I whipped the intermediate pipe from my old exhaust and with penetrating oil I was finally able to get it off.
The morale of this story is find a strong pipe and slide it on the end of the wrench and all bolts should come off no problem (or snap in the process )
-Max
Old Aug 9, 2001 | 09:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
<font face="Verdana, Arial" size="2">Originally posted by maksik7:
The morale of this story is find a strong pipe and slide it on the end of the wrench and all bolts should come off no problem (or snap in the process )</font>
Just wear gloves, you never know what your hands will hit when the bolt snaps...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Aug 9, 2001 | 09:36 AM
Chronos_Titan's Avatar
If I understand you right you have a bolt stuck in the rubber bushing. This happened to me. I could not beat it out or turn it out inshort the bolt was not going anywhere.
The bolt is made out of very hard steel so a regular metal blade will not cut it. Get a good sawzall and you have to buy a carbide blade and these are very expensive. Just suck it up though and it will cut through the bolt in about 5 minutes. Have a some water and a good fire extinguisher ready though because you will catch the bushing on fire. Once this is you are home free.
84 Z28 383
Stripped w/Cage back halved w/ladder bars and coil overs and 9 inch
700R-4 3.73
Old Aug 9, 2001 | 03:40 PM
iroc5speed's Avatar
I may have to go get a sawzall. the bolt turns fine, but it won't back out of the hole. it's very frustrating.
Old Aug 9, 2001 | 03:46 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
If it turns, go get a 5 lb shorty sledge hammer, put the nut on the end to protect the threads and hit it. It'll come out.
While your at the store get a large punch so that you don't have to run back...I always have to go 3 times (at least).
Chris G
91 TA WS6
Old Aug 11, 2001 | 10:27 PM
iroc5speed's Avatar
ok, sawzall not working, bolts turn but do not back out...help please...my car's been on blocks for almost a week. there's gotta be a way to do this.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
cam-mike
Aug 24, 2015 07:23 AM
