Fast Burn 385 engine
Old May 1, 2005 | 05:20 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Ok I'm not sure if this is posted in the correct spot. I need springs which have a minimum of .525" lift for a LT4 hot cam I am installing, and I found springs on ebay.
The springs are listed as 'new take off' from a Fast Burn 385 engine and the guy says max lift is .525" How can I verify this before bidding on the auction?
Also because I require springs because the cam has a max lift of .525", can I get away with springs that have that as a max or should I get springs that can handle .550 or something.
Thanks.
Fast355
Dec 2, 2016 06:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
