a/c recharge or remove?
Old Aug 10, 2001 | 08:53 PM
TransAm182's Avatar
hey my a/c in my 85 trans am needs to be recharged...the thing is i never use it...if i were to have it removed how much would it cost...im no a/c expert so i need everyones help here...thanks...
Old Aug 11, 2001 | 07:19 AM
Bjase's Avatar
Car: 88 IROC
There's really no need to remove it unless you're looking to drop weight for racing, or gain clearance for headers. The defroster uses the AC to dehumidify the air it pumps across the windshield, making it much more effective.
The compressor is easy to ditch, but you'll need some sort of block-off plate or the whole set-up from a non-AC car (blower motor, heater core, housing) if you chose to remove the housing from the firewall.
Old Aug 11, 2001 | 06:10 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Keep it man! You never know when you might want it. It won't hurt much to have it there even if you don't have it working. Hey even if it takes you a year to get it fixed right, at least it is still there.
Later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Aug 11, 2001 | 06:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Get a r134 retro fit kit and a bottle of stop leak & o ring conditioner and charge it up. You will use AC once you try it.
Besides it will help you to resell the car if you ever have to "God forbid".
SSC
Old Aug 11, 2001 | 11:09 PM
iroc5speed's Avatar
go with the retrofit kit. I don't use mine I like windows down, even in the winter...but I do like having the a/c on when it's raining. I like to keep it cool inside and not wet...keep it.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 12, 2001 | 01:54 PM
Iroc n roll's Avatar
Does the car have T-tops? Mine did and my A/C didn't work. So I decided to drop it to unclutter my packed engine bay. I've found that there are a good maybe 7-10 days out of the entire year which I would want to use it and not take off the T-tops. It was worth while for me to get rid of the parasitic loss, weight, and space that the A/C took up. But hey, some guys gotta keep cool, so I guess its up to you and how cold you like your car. However if you don't have T-tops, keep the A/C cause your going to fry in the summer.
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
my86bird
Oct 23, 2015 12:20 PM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
