Metric or SAE
It was the period of changeover. The holes in the engine case that were common to the old design and drilled and tapped on the Ingersoll automatic lines remained as fractional sizes. This prevented any significant retooling and incompatibility with older cases, heads, and such. Smaller and less expensive parts, like intakes, accessories, brackets, and other components were changed over to metric sizes as soon as there was a redisign or new item released.
You would be very upset if your Dart heads and ARP bolts didn't fit the block because the "new" case was made for metrics.
This is another reason for Torx fasteners, There are no metric or fractional sizes for Torx, just the international standards. While the body of the fastener may have a metric or fractional diamter and corresponding pitch, the heads are the same for both.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited August 12, 2001).]
Later,
Vader
SAE? Society of Automotive engineers? There is a "society"? How old are these guys =P Are new cars made in the US still incorporating SAE fasteners? If you're gonna have one standard you might as well use metric. It wont hurt anyone if all new cars were all metric becuase every darn garage already has metric tools.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My 91 truck has a mixture of standard and metric. Even the Hubble telescope has standard and metric. The trouble is where the parts were assembled. The USA still assembled parts with standard fasteners while components that were assembled out of the country (Canada and Mexico being the largest assembled parts suppliers) were already using metric. Until everything was standardized to all metric there can be a real mixture of fasteners. At least were not using british standard sizes.
Depending on the metric size required, most standard tools will still work. Common metric sizes for nuts and bolt heads that don't convert very well are 10, 15 and 18 mm. The sizes in between are either not a common size to use or will have a standard size close enough that it will work.
Even my 91 truck still has standard and metric sizes. There aren't a lot of standard but they're still there.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
If I'm correct, the newer generation SBC III engines are all metric. Many of the newer GM engines are all metric, as well. Since the SBC was designed and first produced in 1954, the fasteners in the main components are still all fractional.
Consider your self lucky that you don't have to deal with clutch head bolts and Robertson heads, like some of the '40s and '50s cars and trucks used. Or better yet, the 19/32" heads used on 7/16" bolts. Then again, explain why some Toyotas (Land Cruiser) have a 120.65mm bolt circle for the wheels. I thought they were all "standard" metric sizes. ¿?
Later,
Vader
Later,
Vader
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
...At least were not using british standard sizes... </font>
Later,
Vader
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by Vader:
Consider your self lucky that you don't have to deal with clutch head bolts and Robertson heads</font>
