starter nose to short
Old May 4, 2005 | 03:17 PM
Riverss's Avatar
I built a sbc 350 tbi and married it to a 700R4, all is fine except that the starter bindix travel is limited by the nose housing from fully engaging the drive gear (168 tooth)on the flex plate. It only engages 1/2 of the ring gear.The starter is shimed properly for proper lash. The flex plate is installed properly. Bendix/delco/remy do not show a diference except for the 153/168 drive housing and mounting blolt position. Is there a chance that someone knows the answer to my problem? I am not going to get a lot of life from the ring gear this way.
Old May 4, 2005 | 03:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Flex plate put on backwards
Old May 4, 2005 | 06:04 PM
Riverss's Avatar
how can you tellif the flex plate is put on backwards?
Old May 4, 2005 | 06:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the starter nose is too short, the flexplate is on backwards.
The "bumps" on the flexplate around the torque converter holes should be sticking out towards the transmission.
Old May 4, 2005 | 06:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Old May 4, 2005 | 10:12 PM
Riverss's Avatar
that is what I have been told and the 'pads','bumps',or what ever are pointed to the torque converter so that the torque converter rests on these pads. any other ideas???????
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
Cleotiz
Sep 16, 2015 08:02 AM
Formula_88AE
Sep 3, 2015 01:47 PM
