car stalls when clutch is in
Subscribe
Aug 13, 2001 | 04:18 PM
i have a '91 z28 5.0L
the car idles poorly, and it has times when it stalls out constantly. I'll be driving and when i press the clutch in, the rpms drop to 0 and the car stalls. It is only when the clutch is in that this happens. Any help would be appreciated.
Reply 0
Aug 13, 2001 | 04:22 PM
You have a TBI or TPI?
Reply 0
Aug 13, 2001 | 04:31 PM
its TPI, i also am getting code 32 quite frequently
Reply 0
Aug 13, 2001 | 06:07 PM
Seems like I read somewhere that the EGR should be closed at idle rpms or the exhaust gas in the cylinder will result in the engine stalling. The code 32 also indicates and EGR system fault (I think).
Z's r Best
Reply 0
Aug 14, 2001 | 11:09 AM
32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
Ya, I second checking the EGR. Hope this helps, go this from the list in the tech section.
1989 GTA 350 TPI
Stock:
- T-tops
- Dual cats
- 9-Bolt 7.75" Rearend
- 3.27 gears
Mods:
- Dynomax Super Turbo Muffler
- K&N Air Filter
1992 RS 305 TBI - Sold
Reply 0
Subscribe
