valves are not rotating with roller tip rocker arms
Old May 7, 2005 | 11:35 AM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
I believe on stock motors the valves should rotate keeping carbon from building up on the exhause valve seats. I have built my 350 and added new valves and comp cams roller tip rockers along with a larger cam, and the correct springs, but I have noticed my valves are not rotating. Should they rotate with foller tip arms? If not this wont cause any problems with carbon in the valve seats? Thanks
Old May 7, 2005 | 09:22 PM
sellmanb's Avatar
Car: '86 Berlinetta
honestly i havent heard that before. To the best of my knowledge valves just go up and down.
Old May 8, 2005 | 07:47 AM
AsphaltAssalter's Avatar
Car: 92 Camaro
A lot of stock engines come with exhaust valve rotator's that take the place of the spring retainer, it's real thick and heavy so they are not used when you buy high performance springs and retainers, they just get tossed in the trash.
Old May 8, 2005 | 12:19 PM
ede's Avatar
ede
don't you think going up and down under XXX pounds of spring pressure would be enough to keep carbon from building up on the seats?
Old May 8, 2005 | 02:47 PM
ar_mcadams's Avatar
Car: 91 camaro
well thats what I would think if the motor was running clean anyway. I was wondering because I have seen the rotators on all the stock heads and thaught that they must be there for a reason.
Old May 8, 2005 | 07:18 PM
ede's Avatar
ede
well you're right the stock rotators are there for a reason, but in actual use they never worked for the intended reason. they did work very well at adding unneeded mass to the valve train while preforming no useful purpose.
db057
Sep 4, 2015 07:57 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
