Prob with idle
Old Aug 14, 2001 | 02:47 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Prob with idle
When i start my car the engine idles fine. But once i drive for a sec the idle will go way up to around 1500-1800 rpms and abruptly go back down again and it'll then idle around 900-1100 rpms. My pcv valve is fine and i don't think its the EGR. Could it be a lean idle mixture? Any ideas?
Red '87FormulaFrebird
-mostly stock 5.0L LG4 V-8 w/cowl induction setup borrowed from '83 TA and T5 tranny. Hey stop laughing i just got it.
Old Aug 14, 2001 | 03:14 AM
Swede's Avatar
I also have the same problem and when I brake real hard after a acceleration the engine stops...
Z28 -87 TPI
white with T-roof
red interior with leather seats
Wagner Borg rear axel
all options
all stock
check Website for info.
www.musikhuset.org/~po/camaro
Old Aug 14, 2001 | 12:34 PM
manuel's Avatar
possible leak thru the Throttle body gasket.
A bad Idle Air control valve.bad Throttle Postition Sensor,bad MAP. All these could not report any error codes.
Old Aug 14, 2001 | 01:05 PM
reborn's Avatar
My car is suppost to idle around 600, but its idling very very roughly at 500 or so. How do I fix this? Is it a carb adjustment?
Old Aug 14, 2001 | 01:46 PM
manuel's Avatar
what you have a craburator? I was taking about TBi.
IF its a carb. then check your choke. and vacumme leaks.
Old Aug 14, 2001 | 10:35 PM
iroc5speed's Avatar
definetly check for vacuum leaks. this caused 70% of carb problems.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 15, 2001 | 02:49 AM
Yes its carbed. Its kind of intriguing because when i go to work in the morning (when the engine is cool), and i first start it idles the way it should. Once i drive for not even a minute it'll idle really high around 1800 rpm for a moment (in subsequent start ups when the engine is still warm it doesn't do that) and then go back down to around 900-1100 rpms the rest of the time, which is a little high, but thats probably a carb adjustment. Could it be a faulty sensor/ECM/q-jet problem (my check engine light goes on about the same time the idle shoots like that for a moment)?
Old Aug 15, 2001 | 03:36 PM
reborn's Avatar
Well I had some spare time and a few bucks so I went and replaced my distributor cap, got a rebuild kit for the distributor, new plugs and wires, air filter and the little return filter thing. Its made a big difference in the idle, its idling at just under 600 now and its a whole lot smoother. It still drops to aroud 400 or so when you let off the gas from about 4k or so for a minute or so of idling before comming back up.
junior419
Apr 7, 2025 11:35 AM
86IROC112
Nov 27, 2015 09:54 AM
customblackbird
Oct 1, 2015 04:30 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
