What recommended engine parts for 350-400 horse.
Old May 8, 2005 | 04:18 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I want to build an engine that makes about 350 horse, maybe a little more. I am getting the Edelbrock Performer RPM heads, and the Edelbrock Pro-Flo TPI intake setup that includes a larger base and runners, but the stock plenum is still used, however i will be port matching everything. The block will be a 4 bolt main with 10:1 compression pistons. What cam should i get. I would like to get one of the LPE cams, like the 211 or 219, but which one, and should i get 1.6 rockers? What about a throttle body, should i get a 52 mm. What size is the stock one? I want it to get decent gas mileage, that is why i am not going to extreme, just want a powerful engine that doesn't use a whole lot of gas.
Old May 8, 2005 | 05:03 PM
daverr's Avatar
why dont u just buy a zz4 crate engine.
Old May 8, 2005 | 05:19 PM
pellmanm's Avatar
Car: 1989 GTA
the zz4 crate costs about 3700 dollars, i would still need to buy a throttle body and a tpi intake set-up, plus the heads are not egr capatible, they don't have hte exhaust cross-over, at least i don't think they do.
Even if i sold the intake that it comes with it would still cost me like 4500 dollars. I can build the same motor, except for the mild forged crank for 3500 dollars. I am a poor college student, so that extra 1000 dollars i could spend on the transmission.
Old May 8, 2005 | 05:23 PM
pellmanm's Avatar
Car: 1989 GTA
So what about the throttle body, i am thinking the 52 mm.
And what about the cam, the 211 or 219, they only difference is that the 211 cam:
211/219 .530/.560 w 1.6 rocker 112 CL
219 cam:
219/219 .560/.560 w 1.6 rocker 112 CL S
The 219 cam has a little more to the intake side, plus both of these numbers are with 1.6 rockers. Would i want 1.5's instead.
Old May 9, 2005 | 09:26 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I have the 219/219 cam in my car. With L98 ported aluminum heads, perfromer RPM intake , and 1.6 roller rockers it makes about 400hp and sounds stock.
If the valve prings can handle the lift, go with 1.6 rockers.
Old May 9, 2005 | 11:04 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Do you mean at the crank it makes 400? Have you had it dyno'd?
Old May 10, 2005 | 08:45 AM
paul_huryk's Avatar
I always refer to crank hp... rear wheel hp is very tricky to estimate with 1/4 mile times - its "power under the curve" that rules those numbers.
I base the 400hp on the weight of the car and what it ran. It ran 12.4 at 113.xx at 3550lb, which is 399hp. It may have a bit more becuase the car is geared a little low and I don't lock up the converter, but I don't like to exagerate the "what if I did this" scenarios (like the import guys do).
The newest issue of Hot Rod has an article on various vortec style heads and their dyno results - they were 395 to 405hp with a similar motor as mine.
Old May 10, 2005 | 11:03 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Id suggest the Lt4 hot cam (w/ the advertised 1.6 rockers of course)for the cam, There are plenty of guys running it and vortec heads making 400hp at the crank, and the heads you have are better than the vortecs. Good Luck.
Old May 11, 2005 | 08:57 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have 304 RWHP which works out to around 380HP at the crank. See signature for specifications. Allen
Old May 11, 2005 | 10:14 PM
pellmanm's Avatar
Car: 1989 GTA
Thanks guys for the input, i have decided to go withthe lt4 hotcam with 1.6 roller rockers.
Jorlain
Aug 24, 2022 05:11 PM
customblackbird
Aug 15, 2021 10:16 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
1nastygta
Aug 8, 2015 07:38 PM
