lift, lsa, duration, ramp speed, centerline how does it all work out?
Old May 9, 2005 | 01:58 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I'm just curious how all these affect the powerband
like adding more lift where would that give more power or is it all over, would it hurt some places. what woudl more lift do for gas mileage?
what about the others like lobe seperation angle or intake/ exhuast centerline what would they do for the powerband
I'm curious how all these would affect the powerband on a car and what they would do for gas mileage also?
like if I wanted to make a cam to get me great gas mileage what would I want to do
what about one for good peak hosepower or maybe low end grunt or if I want a good mid range?
Old May 9, 2005 | 02:05 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Your gonna need a book, or atleast somebody one here to write on for you. I'm sure not right now.
http://www.aptfast.com/APT_Parts/Boo.../B-05_info.htm
Old May 9, 2005 | 04:59 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
lol I have no money for a book
but moer concerned about a gas mileage build right now
trying to get good gas mileage in th 1500-3300rpms range
but curious as far as other aspects as well being friend and I might be working on a 350 soon enough
Old May 9, 2005 | 02:39 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Duration is not good for gas mileage, but make more power because the engine will rev higher and the valves are open longer. LSA effects the power band, a narrow LSA makes a peaky, a wider LSA makes for a flatter torque curve and a much less peaky engine. LSA also effect the amount of valve overlap, wider has less narrow has more. Lift is good but is hard on the valvetrain. It is worthless to increase lift if the head flow can not take advantage of it.
So for gas mileage as wide LSA(114) short duration(210) cam with about .500" lift will be good.
Old May 9, 2005 | 04:58 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
don't some heads work a little different with the lsa as well?
and whats the intake and exhuast center line for?
Old May 14, 2005 | 10:19 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
another question is how does timing the cam have to do with power production and gas mileage?
Old May 14, 2005 | 10:52 PM
sellmanb's Avatar
Car: '86 Berlinetta
These are great questions and I'd love to get the "quick fill in" on all these questions as well... Thanks for asking them RX7speed
Old May 15, 2005 | 12:52 AM
rezinn's Avatar
This article at chevy high performance might help:
http://www.chevyhiperformance.com/techarticles/95298/
I could write up something for you but it wouldn't be as thorough or accurate as an article someone spent time writing like this.
When I think of a cam that makes good power and gives good gas mileage, I think of performance production cams like that in the LT4 or LS1. The powerband depends a whole lot on the cam, but intake, exhaust, and heads are important as well.
This article doesn't really go into lift (as far as I read), but as for adding power, adding more lift will only help if you can flow more air at that higher lift. Sometimes more lift will do nothing but stress your parts, especially with stock heads where flow doesn't increase very proportionally with lift.
InfinityShade
Aug 22, 2015 08:00 PM
perZ
Aug 15, 2015 01:17 PM
anesthes
Aug 8, 2015 09:37 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
