Timing on a 383 stroker?
Old May 9, 2005 | 10:49 AM
WhiteLightnin83's Avatar
Car: 83 Z28
Engine: Mild 383 Stroker
Transmission: B&M TH400 with shift kit
Axle/Gears: 3.73 Limited Slip
i just built a 383 stroker motor and i'm gonna throw a light on it tonight so i'm wondering what should the timing be for it to perform best? thanks
Dustin
Old May 9, 2005 | 11:13 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
The optimal timing depends on your particular setup, especially the cam. Almost any SBC combo works well between 32-36 degrees total timing. You just have to experiment to find what works best for your particular combo. I'm guessing this is a fairly mild street engine, I would try 10-12 degrees initial timing and 34 total..thats a good starting point.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
