Gear ratio's, gear ratio's, gear ratio's...
Old Aug 15, 2001 | 08:59 PM
Slow Iroc's Avatar
86 Iroc, LB9 from the factory, 700R4, GM 10 bolt (as oppossed to the BW), anyone have a clue what gears do you think are in the rear? I would take the car for a drive, but it's not mine. This bone head ripped the engine out, and then asked me how he should build it. We decided on 4.10's, but too order the gears, I have to know what series carrier he has? I know it's a G80 car (like that was hard to figure out). Thanks..
Old Aug 15, 2001 | 09:17 PM
irocbsa's Avatar
Most likely 2.73s. Tha's what most LB9 auto cars got.
bsa
Old Aug 16, 2001 | 01:48 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Could be 2.73's or 3.23's. If you can see the RPO sticker look for the other G codes and look them up in the RPO decoder on this site.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 16, 2001 | 04:45 AM
Slow Iroc's Avatar
Thanks guys, it has the 3.23's. Looks like the original owner of this car gave it some good options, too bad no 5spd.
TPI, Posi, 3.23's, block warmer, oil cooler (didn't even know this was avaliable in 86!), so on and so forth.
Old Aug 16, 2001 | 06:50 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I hope your going to run 1/8 mile if you plan on using 4.10 gears on a tpi.
granted you did not say you were going back with tpi and maybe i assumed wrong.
[This message has been edited by jcb999 (edited August 16, 2001).]
Old Aug 16, 2001 | 12:44 PM
Slow Iroc's Avatar
MiniRam + Direct port NOS eventually
for now....
LTR+Direct port NOS I just don't want to have to do a gear job twice, I hate the smell of that dif. fluid!
Old Aug 16, 2001 | 12:57 PM
ATOMonkey's Avatar
Better get some big A$$ tires.
Old Aug 16, 2001 | 01:50 PM
Chronos_Titan's Avatar
Cruising around a 60 is not so bad.
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
