car is missing, saw sparks comming from the coil
Old May 10, 2005 | 07:43 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
last night i started my car, and everything was fine till i got her going. then i started to notice she'd start bogging whenever i would try to give her part throttle. when i'd step on her, she'd move, but it sounded like she was missing pretty bad. got home with the car on and i could see a spark comming out of the coil. it was comming out of the boot and hitting the metal frame that goes around the coil. what could cause this, and what do i need to do to fix it? get a new coil? the damn coil is like 3 months old lol. it's an msd blaster coil connected to an msd 6al box. thanks in advanced everyone
Old May 10, 2005 | 07:46 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Sounds like a bad coil plugwire to me
Old May 10, 2005 | 10:40 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i thought so too. so i reversed the plug wire to see if it would start doing that on the dist instead of on the coil, but it still sparks right on the coil.
Old May 10, 2005 | 10:55 AM
Nixon1's Avatar
Check the coil and see if the tower or anywhere on it is cracked or broken...
If you have a spare stock one laying around or something it'd be worth a shot to swap it over and see what happens.
I never throw away old parts for a reason....you never know!
Old May 10, 2005 | 11:07 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
good thing you can pick up a MSD blaster coil for $38 on Summit Racing
Old May 10, 2005 | 12:57 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
yeah... i had the stock one somewhere here but i can't seem to find it. i'm going to go get a new coil and see if that works. if it does, then i'll send this one back to msd, get a new one, and keep it somewhere i can find it later incase this coil goes too. i dunno how it would have cracked though... car never overheated, never dropped the thing, and never d*cked with it unless i was taking it out to change an intake gasket. weird.
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
oh btw the guy at msd told me over the phone to use that dielectric grease and everything will work fine. i doubt it will but i'll try it anyway. anyone got something to say about that?
Old May 10, 2005 | 01:22 PM
Nixon1's Avatar
Well dielectric grease will insulate it and might keep it from jumping spark everywhere.....but it doesn't solve the core problem that something is wrong.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Exxon Limited
Aug 9, 2015 08:13 PM
L98GTA87
Aug 5, 2015 11:02 PM
