Oil Sending Unit
Old Aug 16, 2001 | 01:27 PM
Kiss_My_SS's Avatar
Oil Sending Unit
Any help on the location of the oil sending unit on a 92 RS, 305 TBI?
Thanks!
Kiss_My_SS
1992 Camaro RS/Heritage Package
1996 Impala SS
1985 Good ol' Chevy 4x4 Truck
Old Aug 16, 2001 | 01:50 PM
Kiss_My_SS's Avatar
I forgot, it's the L03.
Thanks...
Old Aug 16, 2001 | 02:00 PM
coach's Avatar
It's right above the oil filter. It can be a pain to get off though. Even with the sending unit socket. It's such a tight fit. I remember breaking the plastic part of the old sending unit off with tin snips. I was then able to get the socket onto the o.s.u. in order to remove it. I'm sure there's other ways to do it. Oh, I forgot to mention that it's easier to get to it from beneath the car.
Safety First.
[This message has been edited by coach (edited August 16, 2001).]
Old Aug 16, 2001 | 02:09 PM
Kiss_My_SS's Avatar
I figured it would be in a location where I needed to get under that beast. I read in other posts that the size of the factory OSU and the replacement are slightly different. And this tool you speak of, is it a socket of some sort?
Old Aug 16, 2001 | 02:40 PM
coach's Avatar
It's been a few months since I changed it out, so I don't really remember the size difference. The tool is a deep socket designed for the osu. You should be able to find one at the parts store for under 10 bucks. Make sure you have the right ratchet for the socket(I can't remember if it's a 3/8"drive or 1/2"drive).
Old Aug 16, 2001 | 03:29 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
i just changed my oil sending unit on my 92 and all i did to take mine of was use a pair of vise grips took me 15 minutes to put the car on ramps take off the old one and put on the new one
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Aug 16, 2001 | 03:49 PM
Kiss_My_SS's Avatar
Cool deal. Thanks. Any other info? How much oil will come out when I change it or should I change it during an oil change?
Old Aug 16, 2001 | 04:13 PM
coach's Avatar
You'll probably get a dribble of oil when changing it out, but not a deluge. I didn't wait until an oil change.
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
