Is this normal?
Old May 11, 2005 | 06:10 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Is this normal?
I finished installing my heads and adjusted the valves lash on all the rocker arms, then i noticed the gap between the rocker and the bottom of the rocker arm stud on all the rockers, can someone tell me if this is normal? Thanks
Old May 11, 2005 | 06:59 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
si'
Old May 11, 2005 | 07:14 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
What? Also i have another question, The engine is very hard to turn over by hand. I know that it is not supposed to be easy. I am using 081 heads with harder springs in them, could that be why?
Old May 11, 2005 | 07:18 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
it's not supposed to be easy!
Old May 11, 2005 | 07:20 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I know but is it supposed to be pretty hard?
Old May 11, 2005 | 07:22 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
You're compressing air to 1/10th its size every quarter turn of that crank! Of course it's gonna be hard.
you didn't set your valve lash too tight did you?
Old May 11, 2005 | 07:31 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I dont think so, i used the method where you spin the pushrod and then tighten it until you can spin it any more. look at the picture, do they look normal? I wasnt sure if there were supposed to go all the way down
Old May 11, 2005 | 07:35 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
You don't tighten until you can't spin the pushrod anymore, you tighten until you can't move the pushrod up or down anymore and then go 1/4 to 1/2 turn more.
Old May 11, 2005 | 07:41 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
dang, the article i read said to spin them. and then go 1/2 turn
https://www.thirdgen.org/techbb2/sho...ing+valve+lash
Old May 11, 2005 | 08:22 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Think about it, zero lash is when there is no slack between the rocker and pushrod and lifter and pushrod. It's when they all just touch. You can spin the push rod well past that point especially if the lifter has bled down.
Old May 11, 2005 | 08:32 PM
REALPOWER's Avatar
Transmission: Th350
Hydroulic lifters are pretty forgiving....as long as your close.
Old May 11, 2005 | 08:49 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I agree, but tightening until you can't spin the pushrod at all? I'd say that is too tight.
Old May 11, 2005 | 09:37 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, ill go back and do it the other way. Are the rockers supposed to move alot? The way they are now, i can grab them and pivot them a little bit, is that the way they are supposed to be? Also no one has answered my original question yet, is there supposed to be a gap?
Old May 11, 2005 | 09:53 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Yes there will be a gap, the rocker kind of "floats" between the valve stem and pushrod.
The rockers will seem loose, but will get harder after you get engine running and lifters pump up.
get it close, then once it's up and running you can set them perfectly and your done for a very very long time.
Old May 11, 2005 | 09:55 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok great, but i do not complety understand the concept of valve lash. Do you want to be able to move the rockers? How Much slack should there be?
Old May 11, 2005 | 10:22 PM
IHI's Avatar
IHI
Guess first off, do you have the rocker nuts in the right way? with the radiused side facing down? this could account for some of the variance.
Second, they will feel a little loose until engine is up and running, the slack you fell will be replaced with engine oil and will tighten things up somewhat.
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Once the lifters are pumped up again they will get tight. Do as IHI suggested and get them close. Once the car is running back off the nut until it ticks, tighten untill it just gets quiet and then another 1/4 to 1/2 a turn.
Old May 11, 2005 | 10:54 PM
REALPOWER's Avatar
Transmission: Th350
Not to hijack this thread, but can I see some pics of your exhaust IHI?? Pleeeaseee
Old May 11, 2005 | 11:30 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I usually adjust them while the engine is running. First I tighten them all till they stop ticking. Then one by one I back them off till they tick. Then tighten till it stops + 1/4 turn. Works great. You can buy little things from advance that plug the pushrod hole. Oil will still come by but it will not spray everywhere.
Old May 12, 2005 | 04:12 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
YOu mean the flat side down? Im gonna feel like a real idiot if i have them in wrong
Old May 12, 2005 | 06:38 AM
IHI's Avatar
IHI
The rounded side of the "pivot nut" (dont know what else to call it) goes down towards the head, this way the rocker arm has a surface to pivot on, and when your tightening the nut it has a flat surface to seat on.
Dont feel bad if some are wrong, I've been there done that too
Old May 12, 2005 | 09:21 AM
Cole's Avatar
IHI are you sure about this? I think that the stock setup has "pivot *****" that go under the pivot nut. That gives the rocker it's pivot surface and then the flat side of the nut goes agains the flat side of the ball.
Old May 12, 2005 | 10:13 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Thats what IHI meant, but he called them pivot nuts instead of pivot *****.
Old May 12, 2005 | 12:27 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Well if thats the case then i did it right
Old May 12, 2005 | 05:53 PM
IHI's Avatar
IHI
LOL, too much talk about ***** on here Yeah, that's what I meant
Old May 12, 2005 | 05:54 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
*****, nuts, it's all the same, and we want our cars to have lots of them!
Old May 12, 2005 | 11:13 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
First off, what method did you use? 1/2 and 1/2? One at a time?
Those rockers shouldn't have vast differences from one to another... If they are way off it might indicate that the pressed in studs are pulling out of the heads. This is why people go to screw in studs.
Tighten to zero lash and then 1/4 turn is the ticket. Lifter preload needs to be kept to a minimal to avoid lifter pump up.
If you do it right you won't have to adjust them again probably forever...
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
