pinhole in oilpan
Old May 13, 2005 | 05:14 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
pinhole in oilpan
I found the leak in my car, there is a pinhole in the side of my oilpan. Is there a way to patch his up without having to remove the oilpan? Its a very small hole but its leaking a significant amount of oil so it needs to be patched or whatever.
Old May 13, 2005 | 05:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could clean it up and try JB Weld or RTV. If it doesn't work you're not really out anything.
Old May 13, 2005 | 06:37 PM
2 dope's Avatar
Engine: 305 LG4
what do you mean i wouldnt be out anything? And thanks for teh suggestions, i bought some jb weld ill see how it goes.
Old May 13, 2005 | 07:10 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Can you have someone maybe weld it shut?
Old May 13, 2005 | 07:26 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
JB weld it. Drain the oil first. Then clean it up really good with sandpaper and follow up with a degreaser. Dish soap or the like. Make sure it's free of any soap residue or grease so the jb weld has something to stick to.
I did this several years ago after somebody poked a bunch of holes in my oil pan. Held up fine ever since.
benroc
Jan 18, 2004 04:31 PM
94-6spd
Apr 22, 2003 07:06 PM
bobR
Carburetors
Feb 16, 2003 10:13 PM
Arianboy
Nov 13, 2001 10:18 AM
Mike-88CamaroTBI
Feb 13, 2001 12:03 AM
