Pop Quiz for the TTA specialists... Tech 101.
Old 08-18-2001, 09:54 PM
Vader's Avatar
What was the first production year for turbocharged Buick 231 V-6 engines?
Extra Credit: What is required to adapt one of the old "big" chargers to the later system?
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
Old 08-18-2001, 10:00 PM
1989CamaroRs's Avatar
1978....no extra credit though
89 Camaro Rs
-Stock Tbi 305 with a lot of damn miles
-Edelbrock Z28 TES Headers
-3 inch Catco High Flow Cat
-3 inch Edelbrock Catback
-14x3 Summit Open Element Air Cleaner
-Edelbrock TBI Intake
Stereo
-Pioneer DEH-P4100 cd player
-Polk Dx9 6x9s
also got a 79 Jeep Cj7
Old 08-19-2001, 09:33 AM
Vader's Avatar
89,
Good call on the '78 Regal. That I already knew, but was hoping someone had converted the older turbo to a newer system. I have a line on a Regal system and have been thinking about incorporating it into a project.
The boost control system is largely mechanical and should work well as a retrofit. Anyone else tried this?
Later,
Vader
ede
ede's Avatar
just a WAG but i'll go with 84 or 85. never owned one or been in one, not that i wouldn't like to. i've thought about selling or trading my 68ss for a GN. i remember seeing buddy ingersol at the us nationals in 85 (i think) with his twin turbo twin intercooler buick regal. i loved that car and to watch it run ets and trap speeds close to pro stock cars with twice the engine. i was at the winston points race at indy in may of 87 when he ran his skyhawk for the first time, twin turbo twin intercoolers. it ran a 7.19 @ 198 if i remember correctly and he had to pedal the car all the way down the track and still set the national record for aa/t class. if he could of kept it hooked up it would of ran in the 6's and i think been the first door slammer to run sub7 et's. damn i wish i had a v6 to play with.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old 08-19-2001, 12:24 PM
ArnoldBraker's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ede:
</font>
I don't get it, Why can't you do the same thing with turbos on a V8 and go even faster, easier? Doesn't make sense to me.
Old 08-19-2001, 12:50 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I used to have a 79 Regal Turbo Coupe. Pain in the *** . Yeah, it pulled strong and was not effected at altitude as much as carb cars, but working on the engine was an absolute nightmare. It always had a knock problem under hard acceleration, even with premium gas. It was also very unreliable. Stuff was always breaking. And it had a perpetual oil leak from the valve cover gaskets. Too many damn hoses, you couldn't see the engine for all the hoses and pipes.
I would never even consider buying another.
Just my 2 cents.
Old 08-19-2001, 04:19 PM
Ovrclck350's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ArnoldBraker:
</font>
I think one of the advantages of the TTA and GN's is that they launched with the torque of a 6 (less wheel spin) then boost kicked in.
Old 08-19-2001, 09:04 PM
Jeasen's Avatar
I have a Buick T-Type. It is a 1986 intercooled 3.8 V6. I was at the track a couple of weeks ago. My goal was to run in the 12's on my street tires. After two tries I had to lower the boost to keep from hitting the wall in 2nd gear due to extreme wheel spin. After having to lift in 2nd gear on the third run I finally posted a 13.54 @ 106 MPH. I either need better street tires or less power. I wish my TA would run like that.
Old 08-20-2001, 08:32 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
JEasen you need a set of dot street slicks. Yeah the TTA are bad my brother has one and it is awesome to feel it come off the line.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
jaridjohn
10-05-2015 07:01 AM
Linson
10-01-2015 09:50 PM
paul_huryk
10-01-2015 04:27 PM
Luigytico09
10-01-2015 08:46 AM
Quick Reply: Pop Quiz for the TTA specialists... Tech 101.
