Left over piece out of steering column
Old May 17, 2005 | 10:00 PM
MNformula350's Avatar
So i ended up having to change my ignition lock cylinder (damn vats car and having to snake this new wire through the inside of the column with a big plug on the end) and had my column apart 3 times (cause i put the clockspring on wrong etc...) anyway's i have the piece pictured below left over. the third time i took the column apart to look and i could not see where this piece goes? i have driven the car a couple hundred miles now and everything works fine ( wipers low high and delay, turn signals, tilt, lock cylinder my car does not have cruise, etc...) and wondered what this piece is? i obviously don't NEED it if i have driven the car without any problem, i am just curious as to what it is. i also took apart a spare 84 Manual trans column to look for the part to no avail. thanks
Old May 18, 2005 | 01:22 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
its hard to tell, but it looks like the center piece out of the clock spring
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
