Need pic of how power steering mounts. (v belt) Searched already
Old May 18, 2005 | 09:30 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Need a pic of how the power steering pump mounts with a v-belt setup. Just need to know how the brackets go and such. Searched and found nothing that could help me on the first 5 pages of results, any help is appreciated! Thanks!
Old May 18, 2005 | 10:02 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
the alternator bracket and the power steering pump bracket are one. I don't understand your pic request...
Old May 18, 2005 | 11:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think not.... The alt is on the pass side, the PS pump is on the driver's side.
Put this one on first. Goes on the front of the block, and the front-most exh manifold stud, after it's installed through the manifold.
Attached Thumbnails Need pic of how power steering mounts. (v belt) Searched already-lower-bracket-front.jpg
Old May 18, 2005 | 11:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's how it goes over the mainfold. That little round part sticking out the back of the A/C bracket, goes into a hole in the other A/C bracket, which goes on on top of that first bracket, on the 2 front exh man bolts.
Attached Thumbnails Need pic of how power steering mounts. (v belt) Searched already-front-upper-side-view.jpg
Old May 18, 2005 | 11:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Then the pump itself goes on, like this. Note that there are 4 attachment points; the stud in the front of the head, the adj bolt into the water pump, one bolt on the back of it, and one nut on the back, down low.
Attached Thumbnails Need pic of how power steering mounts. (v belt) Searched already-ps-pump-detail.jpg
Old May 18, 2005 | 11:44 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
You're probably right, but on my car they are of one and the same. Oh well, I'll walk away from this thread.
Attached Thumbnails Need pic of how power steering mounts. (v belt) Searched already-swap4.jpg
Old May 18, 2005 | 11:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You have a serpentine belt, he asked about V belts.
Old May 19, 2005 | 12:29 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
LOL
I think I can explain what happened. I probably saw that it was a V-belt question, and out of intellect I clicked it to learn something new. But then, yeah, I probably thought in my head "oh you know what, lets answer this because I'm an idiot"
AS I SAID, I AM JUST WALKING OUT OF THIS THREAD RIGHT NOW!!!
Old May 19, 2005 | 04:39 AM
hahaha
thanks guys
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
backtothe80s
Sep 5, 2015 12:39 AM
