Key out, engine stays running? PLEASE HELP
Old Aug 22, 2001 | 03:58 PM
rscamaro91's Avatar
Ok, I have a 91 camaro with the 3.1 lier V6. This has only happened 3 times in the last 8 months, but I need to figure out why it happens. When I turn the key off, I pull it out and realize the engine is still running, WTF???? I popped my hood and looked under there wondering what to do, so I shut my hood and the engine shut off. Any ideas on what could be causing this??????? Thanks in advance for your help
Old Aug 22, 2001 | 04:03 PM
Z28fromItaly's Avatar
I think it must be a problem in the ignition switch, fixed on the right side of the steering column
Old Aug 22, 2001 | 04:06 PM
rscamaro91's Avatar
Why do u think that by slamming the hood down, it shuts off?
yOp 84 Recaro's Avatar
Strange problem.. Used to happened to my dad's old Chevy Astro (remember those ugly minivans) .. key was so worn down you could just pull it out anytime...
Old Aug 22, 2001 | 04:11 PM
rscamaro91's Avatar
the key is no problem, it is brand new and will not come out until u turn the ignition to where it will. Any other ideas....
Old Aug 22, 2001 | 06:38 PM
Stuart Moss's Avatar
Strickly a guess, but I agree with the post about the ignition switch sticking in the "on" position.
The ignition key moves a lever to the actual switch contacts located further down the steering wheel column. With the ignition key out, somehow, someway, the switch contact(s) did not open enough to break the connection.
Slamming the hood was enough to knock the contact(s) to their proper position.
Without having looked at the contacts of this switch to see if this could even be possible, I am at a loss to speculate what else it could be.
Removing this switch and examining it may show something excessively worn or broken. If everything appears normal, can it be opened for examination?
Since it only happened a few times, I would suspect something that has become worn - such as too much slop in the lever moving the switch contacts...
Old Aug 22, 2001 | 06:53 PM
rscamaro91's Avatar
Thanks for the reply, that sounds like a logical explanation. If it doesnt happen for another few months, i probably wont even fool with trying to fix it. Thanks for your help...
Old Aug 22, 2001 | 08:44 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
There is a rod that actuates the ignition switch. Granted if it is fried it does not preclude the possibility of it being the culprit. Are you sure you were not experiencing run-on? Do you by chance have an MSD ignition?
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Aug 22, 2001 | 08:54 PM
rscamaro91's Avatar
no, I have no ignition mods whatsoever, i mean the car was running like it normally would except that i couldnt put it into gear or ne thing lik that, so im going to assume it is something to do with that rod u mentioned.....
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
