DOH!!! Clay tested heads, now I may have clay in piston rings?
Old May 21, 2005 | 06:46 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I used plumbing putty to test valve to piston clearance on my rebuild. Problem is: it smooshed some putty inbetween the piston and bore. I rotated the engine several times before I took the head back off. There was a little bit of clay smeared on the bore. I think I cleaned all of it out of the gap with folded paper and oil, but I am worried that there could still be some in there (between the rings) that could mess stuff up. The bore and piston looks clean when I rotate the engine now.
Is this clean enough? Or do I have to tahe the pan back off and remove the piston?
Old May 21, 2005 | 09:03 PM
ede's Avatar
ede
think path of least resistance, going past the rings isn't it, unless you used a gallon of it. clean it up and don't worry about it
Old May 21, 2005 | 09:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd be concerned with what happens to it when heated...i/e does it cause a build up behind the rings in the lands, does it harden like nails?
If it deteriorates on heat, then no problem, but you may want to call the manufacturer and find out it properties.
Hate to see the stuff get hard as nails and start galling the cylinders.
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
