running rich
Old May 21, 2005 | 08:05 PM
mocappa's Avatar
Car: 1989 GTA
Engine: 5.7L
running rich
I have an 1989 GTA, 5.7L, auto, running rich enough that after lettting it idle for about 10 miniuets three or four times, while I'm trying to figure out the problem, the plugs are so fouled it won't start and I have to change them. I replaced the computer, MAF, oxygen sensor, and thermostat sensor. I also used a Snap-On diagnostic machine to check the IAC, TPS and every other sensor I could. Diagnostic show everthing working properly and I even have proper fuel pressure. I have no experience with TPI and am completely stumped. Any help/advice would be greatly appreciated.
Old May 21, 2005 | 08:51 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well heck, welcome to thirdgen.org!!!
I'd have to ask if the scanner shows the rich condition or not?
From what you describe, sure sounds like fuel is dumping in way too fast for normal diag.
May want to pull the vacuum line at the fuel pressure regulator and smell for gas, could be it;s ruptured and needs replacing.
Check the crankcase for fuel? best to do first to be sure you're not working on a potential bomb...hate to see shrapnel blow though a body...eyyuuuck!!!
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
