Ideas for a sound rebuild???
Old Aug 22, 2001 | 10:29 PM
craiger's Avatar
Recently, I just did a compression check and found one cylinder reading a good 50 psi lower that the rest of the cylinders in my Z28. I put 5cc's of oil in the cylinder with a low reading and the psi increased from 120psi to 155psi, all other cylinders read 170psi. I'm not too excited to tell my wife the bad news But a man's gotta do what a man's gotta do! Now, I have a few questions for the rebuild. I plan to put eagle rods with hyperutecic pistions and balance the motor. I am wondering what will increase my horsepower best bang for the buck. I have a supercharger on the car running 8lbs of boost. I am contemplating putting a set of AFR's on the car and leaving the stock cam or porting a set of stock l98 heads and putting 1.6 exhaust valves in and a larger cam ( compucam 2032r). I have a good line on the afr's for about 1000 bucks. To get the heads and cam would cost me about 650. What should i do?
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
fbirdroller
Sep 2, 2015 10:27 PM
formula_novice
Aug 18, 2015 08:48 PM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
