Puddle in back seat
Old Aug 22, 2001 | 04:07 PM
92Camaro305TBI's Avatar
Puddle in back seat
My dads 92 RS 3.1L For some reason has been gathering water/liquid in the back drives floor. He first noticed a stinch and then after it didn't go away looked for the cause.. Well He found it in the back drivers floor.... BUT WHERE IS IT COMING FROM. He sucked it up with a wetvac thingy. Then left a fan on it over night.. When he drove home from work the next night after drying it.. it was there again.. like an inch deep of liquid.
What type of tubing ot hoses lead to the back seat floor only? Couln't think of anything in the engine leaking without going to the front first.. any help guys.... PLease list ideas also.
Old Aug 22, 2001 | 04:19 PM
iroc5speed's Avatar
well, this may be bad news.the fuel lines lead right along the driver's side floorboard. you may want to check on that.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 22, 2001 | 04:28 PM
funny it doesn't smell like gas... Smells like old rice gravy or something like that
Old Aug 22, 2001 | 04:32 PM
GTA88's Avatar
Maybe rain got in an open window ? After you wetvaced it, surrounding wetness may have seeped back down to that low spot. Just guessing. I had a stench from the same spot. Turned out the mech must have left the driver window open during a storm. A newspaper under the floormat back there got wet and stayed wet. That was about 3 weeks ago. Just found it yesterday !
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Aug 22, 2001 | 04:44 PM
That may be it.. but there doesn't seem to be a leak, Ill have to take a closer look.
Old Aug 22, 2001 | 06:15 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Does the car have t-tops? If so I'll bet the farm they are leaking. If it doesn't then I have no idea. There is no way for fuel to get into that area unless it magically goes through the floor pan, and no other fluids run in that area.
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
Old Aug 22, 2001 | 07:10 PM
rezinn's Avatar
How cold does it get at night there? Are the windows really fogged up in the morning? If so, some moisture got in somehow and is condensing on you windows and collecting in the back seat - happened to me once, and it was annoying, but it cleaned my carpets
Old Aug 22, 2001 | 08:36 PM
BARRY 91T/A's Avatar
are any of the front floorboards wet at all? it could be his heater coil leaking and running under the carpet to the back? does it smell like antifreeze at all?,,might check this if not only other thing it could be is t-tops leaking,,
Old Aug 22, 2001 | 09:36 PM
iroc5speed's Avatar
my hatch floor used to get wet from the bottom when it rained. Put a floormat down after drying the area. Next time it gets wet, see if the top of the floormat is wet too. If it isn't, it's coming from the bottow or seeping down from around the floormats. I guess you would've smelled fuel if it was that, I wasn't thinking too clearly.
'86 IROC 5-speed
305 LG4
msd pro billet hei distributer
'95 3.23 rearend
PST front polygraphite suspension
Old Aug 22, 2001 | 10:58 PM
No t-TOPs.... not fuel... Ill check the anti-freeze... not its too much liquid to be fog off the window... Maybe the heater thingy.. but.. i havent noticed anything wet in the front seats...
Guess I could pull the carpet... Thanks guys....
Old Aug 22, 2001 | 11:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd shoot the neighbors cat, hell, even if it's not the cat, you've eliminated one potential problem.
Old Aug 23, 2001 | 12:11 AM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 8Mike9:
I'd shoot the neighbors cat, hell, even if it's not the cat, you've eliminated one potential problem.</font>
LOL, They go good with gravy.
Old Aug 23, 2001 | 12:18 AM
TransAm4u2race's Avatar
dopnt think it can seep in from the bottom. Enough might seep in to get the carpet wet but it wont have an inch of water in there cuz wherever it came in the floor at gravity will pull it right back out. not being sarcastic or anything just trying to help out. check your hatch seals...
Old Aug 23, 2001 | 12:37 AM
coach's Avatar
I had a similar problem in an '84 Z-28. It went away on its own. The only thing I can think of that hasn't been mentioned is liquid from the a/c. After you turn the car off, you'll notice water(I guess condesation) drip to the ground. Some of that is probably making it's way down the floorpan or chassis somehow. That is just a guess, though.
Fast355
Dec 2, 2016 06:33 PM
lee01
Apr 9, 2016 01:56 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Leggman1
Aug 6, 2015 04:15 AM
