Underdrive Pulley Queston
Old Aug 23, 2001 | 02:59 PM
greyZ's Avatar
I've heard stories about under-drive pulleys causing charging and cooling problems on daily drivers. But they were from using 2 and 3 pulley systems.
What effect would, using only, an under-drive crank pulley have on the alternator and water pump operation?
And could you expect any performance gains?
1985 Z28
305 LG4/700R-4
bone stock right now
Old Aug 23, 2001 | 03:33 PM
ATOMonkey's Avatar
It doesn't matter wheather you increase the accessory pulley size or decrease the crank pulley size. The end result is that the accessories spin slower. This is where the power gain comes from. It takes less torque to turn the accessories.
Old Aug 23, 2001 | 04:10 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I had charging problems with my original March pulley set. I have since switched to their "Power and Amp" pulleys and have no charging problems any longer. What they did was change the diameter of the alternator pulley that allows the alt to spin faster.
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Old Aug 23, 2001 | 04:14 PM
poncho9789's Avatar
IMHO underdrive pullys are a waste of money and time. Do some reserch and talk to people with the third gens and most can tell you the best bang for the buck mods on the market.
good luck.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
Old Aug 23, 2001 | 11:19 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I took out a 305 camaro the other day. He probably needed a tune-up though, heh.
-88-v6-k&n-flows-jet chip-cam
Poncho - any idea how fast you are with all those mods on your GTA? I have an 88 gta along with my 6'er and i want to mod it up too. Thanks~!
Old Aug 23, 2001 | 11:21 PM
Car: '89 GTA
Oops, the takin' out the 305 was for the "norock5.7" listing, my bad. ;-)
Old Aug 24, 2001 | 08:44 AM
greyZ's Avatar
The reason why I'm asking is because I just bought an underdrive crank pulley off e-bay because it was cheap, $8 bucks. And I don't know if I want to install it or not.
Thanks for the replys, though.
1985 Z28
305 LG4/700R-4
Old Aug 24, 2001 | 09:00 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
If your just running 2.73 gears your car might not turn enough RPM to keep a good charge going. If you your running in the 3.x's you should be fine. I ran my car 6 months with just crank pulley and it was fine. Thought motor reved faster with pulley.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
<p><img border="0" src="http://www.bharris.org/images/smcamconv.jpg" width="200" height="73"></p>
Old Aug 24, 2001 | 10:43 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
You should be alright. The two pulley sets slow down the crank and the alternator, so just a crank pulley shouldn't give you any trouble...if it does, swap 'em back.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Aug 24, 2001 | 11:40 AM
Biochem's Avatar
Car: 2002 SOM z28
I got a 25% underdrive crank pulley and I really don't have too many charging problems. Besides, who stays at 1000 rpms for any great length of time while driving anyways?
My main problem is the cooling problem. I have a Stewart pump, a monster Griffen radiator, and a 160F thermostat and it goes through the roof on hot days in traffic. On the highway, absolutely no problems, but if I sit for more than 10 minutes I will be at 260F and beyond! I seriously fear gridlock and rush hour traffic...
It was worth maybe a little SOTP difference at the upper rpms.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
