LT1 Intake Matched to Vortec Heads
Old May 26, 2005 | 09:35 PM
JayB's Avatar
Can this be done? I know the vortec heads require special intakes, but can the two be paired? Or would the LT1 Heads be an easier choice.
Also, does anyone have a link to the artice where LT1 Heads are matched to a GEN I Small block???
Old May 26, 2005 | 10:55 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Anything is possible with $$$
Old May 27, 2005 | 12:54 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Re: LT1 Intake Matched to Vortec Heads
http://www.lt1intake.com is all you need for a basic Lt1 swap. If you want Vortec heads, buy an LT4 intake from Summit for $250-ish and adapt the LT4 intake the same way.
Old May 27, 2005 | 06:49 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
if you're using vortec heads why not just get a vortec style intake?most cost less than$250 anyway.
Eric B
Old May 27, 2005 | 08:49 PM
firehawkslplus's Avatar
Car: 91 Firebird Dark Green
Engine: 350 Victor Jr. 2V 2000 CFM TB EFI
Transmission: 700R4 BM 2500 stall
Axle/Gears: 3.73 Zexel torque sensing Posi
Lt1 heads on SBC gen 1 block
Jayb check your mail
I have the article scanned can send need E-mail add.
Old May 28, 2005 | 11:12 PM
JayB's Avatar
james@softnice.com
Old May 29, 2005 | 01:14 AM
Re: Lt1 heads on gen 1 SBC Blk
JayB check now
Old May 29, 2005 | 09:28 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I'm getting to the point where I am going to give this a shot(lt1 intake and vortecs) I think.
Distributor mods will be the same.
Coolant mods will be the same.
Bolt holes will be the biggest issue as the vortecs only have the 4 bolts on each side(8 total) 2 frt and 2 rear holes on each side.(they are striaght up and down)
I can see existing material on the base may have to be added to and/or added to and then cut down flush to make a pad for the bolts to sit on
I believe the local junkyard has a L99 car and can jack the intake off of.
If someone has an L99 intake and/or a LT4 intake and access to some vortec heads I would appreciate some pics to help with planning.
If anyone here has actually done it or can post pics of someone who has, it would be appreciated. It's often rumored and never seen :-)
It wouldnt cost me alot and I do my own tuning, I do not want to cut the hood for a stealthram and who knows when we will see the BBK intake.
Should liven up a 383 now wouldnt it :-)
later
Jeremy
Old Jun 20, 2005 | 09:47 AM
bnoon's Avatar
Oops, no message...
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
