Leaded Gas?
Old Jun 18, 2005 | 10:04 PM
olong_us's Avatar
Car: 1986 IROC Weekend, Jetta VR6 Daily
Engine: 350 .030 over 5.7 TPI
Transmission: 700-R4 Rebuilt
Leaded Gas?
Ive got this friend that drives a 5.0 and tonight he put leaded gas in his car. Now his cat is gutted so it cant be ruined but what harm will this do to his car?
Old Jun 18, 2005 | 10:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It will kill an O2 sensor if he still uses one.
Leaded fuel acts like a lubricant on valves. It also slows down the burning of fuel which increases the octane.
As for damage to the engine, none.
Old Jun 19, 2005 | 11:02 AM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
where'd he get leaded gas at anyway? it was outlawed over 20 years ago
Old Jun 19, 2005 | 12:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Probably Avgas LL100
Old Jun 19, 2005 | 12:43 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
As Stephen pointed out it's leagal to use avation fuel. I use to be able to get it years ago.
Old Jun 19, 2005 | 01:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I've known people at the track who used to use avgas but found buying proper race gas is better.
Old Jun 19, 2005 | 01:24 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
leaded gas might be outlawed.. but you can still buy the lead additive for the gas as well. I have to buy lead addittive for my 1952 chevy truck, since it has all the original parts in it yet. They just do not build engines like they used to.... Only thing we realy have done was have new valve seals put in.
Old Jun 19, 2005 | 08:31 PM
olong_us's Avatar
Its called CAM 2. It is leaded gas. It wasnt really for automobile use. The nozzel was twice as big as the hole in the filler neck. he had to us a funnel to put it in the tank. Its mostly for motorcross races and ATV's
Old Jun 19, 2005 | 09:43 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
you can get lead additive at autozone for not that much $$
Old Jun 19, 2005 | 10:26 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's nothing special, just diesel mixed with die and some other chemical. Bearly keeps the valves lubed I run it in the 56 Buick.
Old Jun 20, 2005 | 11:04 AM
contact's Avatar
Engine: sbc 350
The real lead additive is called 'Max Lead',
I think there is another brand that is similiar.
The stuff in little bottles is a fraud.
People running leaded gas should consider using
a lead-tolerant O2 sensor.
I would think that avgas 100 LL would be OK
a lot of the time, unless you are in a
racing class that checks fuel.
Price check...
who has purchased Xylene, recently?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
Glowsock
Sep 11, 2015 11:09 PM
TBRays98
Sep 6, 2015 05:05 PM
