Hard Starting Fixed!!!
Old Aug 24, 2001 | 09:58 AM
88 IROC BOB's Avatar
Finally its fixed! You all know the routine-starts fine in the morning but has a hard time any other time throughout the day.
I had suspected the fuel injectors and actually sent them out to be cleaned and was told they were good but the problem still persisted.
I was still losing pressure when the car was shut off. It turned out the #1 injector would leak for 15 min. after it was shut off.
I replaced them all with 23# Accel injectors and it fires right up anytime of the day now.
Just thought I'd spread some good news here instead of my usual "why's my car doing this".
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Aug 24, 2001 | 11:18 AM
Biochem's Avatar
Car: 2002 SOM z28
Thanks for sharing and glad you got your car working right again! You are right... not enough replies about what fixes the problems after something works
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Aug 25, 2001 | 10:17 PM
Thanks, I just think that more people with this problem should just replace their injectors with new ones. GM obviosly had a big problem with these since I have read far too many posts about the same problem.
Bob
Old Aug 26, 2001 | 01:58 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
how did you find out the #1 injector was leaking? How much were the new injectors? I have a 305, but did you retain the stock 21lb. pressure for your TPI?
I have this same problem.
[This message has been edited by yellowiroc2 (edited August 26, 2001).]
Old Aug 26, 2001 | 04:27 PM
To figure out what was leaking I left the the fuel fail connected but unbolted it and lifted it up. Then when the fuel line is pressurized (turning the key on but not starting it) I could see fuel dripping out of the injector.
I went with Accel 23# which I bought thru www.cruzinperformance.com
So far I have left the fuel pressure the same (44psi). I know that the new injectors will flow more but I could probably use it with the intake and exhaust mods.
Hope this helps!
Bob
Old Aug 26, 2001 | 04:28 PM
Oh yeah the injectors were $229 for the new ones.
Bob
Old Aug 26, 2001 | 07:56 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
ok man, thanks for the info.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
