smoke at start up
Old May 29, 2005 | 06:52 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
smoke at start up
I started the 91 GTA yesterday and saw white smoke coming out of the back of my car.
From previous posts it looks like I have bad seals. Is this a correct assumption? (or is it coolant?)
Can someone provide some details about my problem?
How much is this going to cost to get fixed by a mechanic? What parts do I need? Do I need to have the inside of my engine cleaned out? Will there be any problem if I let my car run for another couple of weeks without getting it fixed right away? (just idling in the driveway)
Thanks,
Bill
Old May 29, 2005 | 08:31 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Blueish/white smoke at start up in very common, normally it's an indication of bad valve seals. GM has a TSB about the problem and a fix kit. They switch to a positive umbrella seal and use a viton insert. The part # is 12511890 for the kit. Labor will average anywhere from $300-500 for the job. As far as operating the car it is fine, you could run it forever that way.
Old May 30, 2005 | 09:45 AM
wgripp's Avatar
You guys wanna come up and do it for me for some free beer? It would save me $500
Bill
Old May 31, 2005 | 09:57 AM
wgripp's Avatar
Is it the same part number for the 305 and 350?
Calling GM dealerships, it looks like they want like $52 for the part, and $600 for labor. GEEZ
-Bill
Old May 31, 2005 | 10:01 AM
wgripp's Avatar
Another dealer says i need new valve cover gaskets as well as the kit. (He hasn't looked at my car, I just gave him the part number and asked for an estimate on the installation.) Do I need this part? Are there any other parts I need?
This guy wants $900 for parts and labor. Holy ****. Looks like I'm going to a local mechanic, and I hope he doesn't screw up my car.
Old May 31, 2005 | 11:42 AM
wgripp's Avatar
Local mech want's 650 (not including parts), and he's the cheapest guy around. -slams head on desk-
Old May 31, 2005 | 12:07 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Bill, how many miles do you have on your motor? If it's over
75,000 you may consider pulling the heads and getting a valve
job at the same time. Or getting those aftermarket heads you know
you always wanted.....
If you decide to just do seals, you will need valve cover gaskets
because the valve covers have to come off to get to the seals.
(BTW, is an excellent time to change those fatigued valve springs).
You can go aftermarket for valve seals (intake Fel-Pro PN#ss72527
and exhaust Fel-Pro PN#ss72877), and valve cover gaskets are
PN#vs50088r for the good Permatorque gaskets.
Old May 31, 2005 | 02:12 PM
wgripp's Avatar
The car has under 50K on it. M. Hall, now you made me excited. I called the mechanic back and asked how much he'd charge to install all kinds of new goodies on my top end.
It looks like I might be going with aftermarket heads, a new cam, and a new throttle body.
I'm going to move to a new thread, so I can ask some questions about redoing my top end. Look for it!
Bill
Old May 31, 2005 | 03:12 PM
'Shifter's Avatar
Car: 87 Z-28
Old Jun 8, 2005 | 01:53 AM
transamracer's Avatar
Car: 1988 Trans AM GTA
Engine: 5.7L Tuned Port Injection
Axle/Gears: 9 Bolt 3.27
this kit #12511890 does it come with 16 umbrella seals, or just 8 for intakes? are they a direct fit, no machining of the guides required? How would I order after market ones that are a direct fit?
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
