No spark what-so-ever need help asap
Old May 30, 2005 | 11:58 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Well I was driving and out of no where the car started hesitating bad, so i pulled off the 2 lane road onto a back road where it got worse It was like this...... "Chug chug chug POW" loud azz back fire. Well I checked, I have no spark, I'm getting fuel. I have a new dist cap and new wires. What should I buy to fix this.
ps some guy dolley'd me home, the bottom gfx is all blue and broke in half and also the whole 1 side of the bumper is blue and scratched up from the damn dolley turning and ****. I'm furious
Old May 30, 2005 | 12:04 PM
Car: 2002 SS
Engine: Ls1
heres damn pictures
Old May 30, 2005 | 12:06 PM
Car: 2002 SS
Engine: Ls1
1 more btw got clear sidemarkers, nice way to present them isnt it
Old May 30, 2005 | 12:31 PM
91Z-TheReaper's Avatar
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
Mine had the same problem a couple of weeks ago.
I had to replace my starter and the dizzy and coil...
As for the damage, you should be able to make the company that towed you pay for it.
I had to have mine towed as a result of this problem...tow operator screwed up so I got a free tow and my front gfx repainted (needed to paint it anyway, but with their carelessness, I'll take the free job) all for their cost - $1000
As long as you can get the driver/company to admit responsibility, you should be able to get them to pay. Threaten that you'll go through insurance, worst case...
Old May 30, 2005 | 12:42 PM
Car: 2002 SS
Engine: Ls1
a guy did it for me for free.. just some random dude. but anyway whats the dizzy?
Old May 30, 2005 | 12:50 PM
Car: 2002 SS
Engine: Ls1
this is the only thing i coudl get off? what is this and what do i need to take out
Car: 88 IROC
Engine: 350 L98
Sorry to hear that. Good intentions I guess...
Dizzy = distributor. I see you got a new cap. Maybe you want to check the internals - rotor, coil, etc... - check the plugs themselves (I would check plugs first).
I'm no pro, so don't go blowing your money on anything just yet. But I think that is the right direction so it will at least get you started. I think it has to be distributor related.
Old May 30, 2005 | 01:10 PM
Jschoepf's Avatar
Car: 1986 Trans Am
Engine: 6.0L LQ4
I had a problem similar to this, turns out my rotary button inside the distributer cap had broken loose, and was spinning cutting my distributer cap to hell. (Best way I know to explain what happened)
Old May 30, 2005 | 01:39 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
If it is not dented, why not just get some rubbing compound and buff it out?
Old May 30, 2005 | 01:58 PM
Car: 2002 SS
Engine: Ls1
I REPLACED THE IGNITION MODULE. NOW WHAT SHOULD I DO?
Old May 30, 2005 | 02:11 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Check the pick up coil, check the resistance on your fuel injectors, if they go bad it can burn up the ecm and then there will be no reference pulse to initiate spark. You could also get a noid light and check for injector pulse.
Old May 30, 2005 | 02:13 PM
Car: 2002 SS
Engine: Ls1
whats the pick up coil? that circle around the center of the dist? and if so how do i get that off?
Old May 30, 2005 | 02:16 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Man who cares about that V6! Put your Vortec in!
Old May 30, 2005 | 03:37 PM
Car: 2002 SS
Engine: Ls1
So I changed the coil and the ignition module and still no spark! wtf. What else could it be?
Old May 30, 2005 | 03:47 PM
Car: 2002 SS
Engine: Ls1
And I have power to the coil, i checked the pink wire
Old May 30, 2005 | 04:30 PM
Car: 2002 SS
Engine: Ls1
alright screw you guys then. I have someone coming to get my car tomorrow
Old May 31, 2005 | 09:58 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
What do you mean screw you guys, i gave you a list of things to check.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
