how to do a compression check?
Old Aug 27, 2001 | 05:33 AM
IH8FORD's Avatar
Kinda self explanatory. As always thats for the info.
Old Aug 27, 2001 | 11:58 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The technique is detailed in any decent repair manual, but here's a Reader's Digest version:
1st, you need a compression gage. The screw-in type are a little easier to use by yourself.
Remove all of the spark plugs. Disconnect the power wire to the distributor/coil.
Hold the throttle wide open. With the gage installed in one cylinder, crank the engine over with the starter for 3 or 4 compression strokes (a remote starter switch or helper good here, especially if your gage isn't the screw-in type). Record the reading for that cylinder, repeat for remaining cylinders.
If readings are low, repeat the tests having put about a tablespoon of oil in the cylinder before the test (this is known as a "wet" test). If readings go up significantly, you've likely got bad rings.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 27, 2001 | 04:36 PM
Duke901's Avatar
Car: 89 Formula
But when you turn it over wont the injectors be letting gas in and flood the engine
Old Aug 27, 2001 | 05:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, if you have FI, it would be a good idea to unplug the injectors. If you have a carb you don't have to do anything to it.
ICON Motorsports
Old Aug 28, 2001 | 04:12 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
No, if you have FI the computer goes into 'clear flood' mode and shuts the injectors down above 80% throttle.
If you are doing the check in very cold weather, disconnect the CSI plug on the front of the intake manifold or remove the 3A crank fuse, if your car is so equipped, but since it's pretty warm out I wouldn't bother.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
