Cam question
Car: 1991 Camaro Z28
Cam question
Possible to run this cam...
http://www.compcams.com/base/process...=93&submit.y=8
with a superram setup with a modified PROM. Would the prom accept it?
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: B&B Exhaust, few free mods.
Appearance Mods: SS wheels, 2.5" Cowl Hood... New 100% Black paint job, Clear Side Marker Lights
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Pictures at Here
ICQ: 1437212
AOL: normalmatt9
91 Z28
Best Time Slip:
60' - 2.098
Pictures at Here
ICQ: 1437212
AOL: normalmatt9
Car: 88 Firebird WS6
Maybe with 11:1 or better compression, a 383 or better ci and 3.73 or better gears.
Too big, and the 110 LSA will kill vacuum to the brakes.
Could be done in a very light car with a 350. Then again a mini-ram would be a better choice, even with more cubes.
[This message has been edited by JoelOl75 (edited August 28, 2001).]
Car: 4
Engine: 6
Transmission: 5
That XR288HR is WAAAAAAAAAAAYYYYYYYYYY too much cam for anything approaching a long-tube setup on a stock L98 long block. The cams that work best with the SR seem to be in the 218-224 intake duration range, with as much lift as possible; and it does no good to go larger unless you use heads that have some flow (NOT stock ones).
I helped out a friend with a 434 with Edlebrock RPM heads, a Haltech, and Accel Pro Ram, we put a XR282HR in it, and that was almost too much cam, in a much bigger motor than yours. And that of course was with a Haltech which is a whole lot easier to dial in than a stock computer. It ran great but was a bear to get to idle right and to behave at part throttle.
ICON Motorsports
ICON Motorsports
Here is where I got it at...
http://www.airflowresearch.com/chevy_dyno.htm
They made 500hp out of it. A 383 making over 500hp. Pretty damn impressive seeing as it's running only 9.4 compression...
The reason I asked... is it's Carbed I want fuel injection... but I don't think it would work the same.
So could it work on the stock prom... when running the Superram? Well, stock as in same one... but have been reprogrammed to try and take it?
91 Z28
Best Time Slip:
60' - 2.098
Pictures at Here
ICQ: 1437212
AOL: normalmatt9
91 Z28
Best Time Slip:
60' - 2.098
Pictures at Here
ICQ: 1437212
AOL: normalmatt9
