13's with only free mods, can it be done?
Old Aug 24, 2001 | 11:05 PM
rallysport's Avatar
Has anyone thought about a 13 second third gen. with only free mods. Okay even with very little spent. I know nothing is free. So lets see. What about a gutted cat (free), serious weight reduction (free), Maf screens (free), custom ram air (almost free), ported plenum and runners (gaskets and dremel bits), ported and polishied heads (gaskets and bits also), change timing(free). The only money I see is head gaskets, intake gaskets, plenum gaskets, and dremel bits. very low cost are 13's possible and are there anymore free or low cost mods out there?
Old Aug 24, 2001 | 11:06 PM
rallysport's Avatar
by the way you would have to have a 350 tpi to start. I would imagine. I am wondering this because I have an 88 tpi 350 Gta.
Old Aug 24, 2001 | 11:39 PM
One Eyed Jack's Avatar
Yeah, 13s can be done. Assuming you steal the parts :P I dont know, just try boosting your fuel pressure way up and stuff for now.
Old Aug 25, 2001 | 01:38 PM
rallysport's Avatar
t
Old Aug 25, 2001 | 11:52 PM
Xenodrgn's Avatar
Serious weight reduction will put any car into the 13's... however even aluminum frames weigh something...
I don't know anything about 350's (myself being a V6'er)... but I'd think you'd at least need a cam or NOS.
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Aug 26, 2001 | 05:25 AM
91'firebrd's Avatar
I think it can be done if you have new tires and the right gears. Without those it might be better to shoot for 100 mph across the line. Then its just a question of power and takes traction out of the equation.
Old Aug 26, 2001 | 05:52 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Maybe, if u have 1 of the L98's that came stock running 14.1-14.2, which they don't always do, u probably would be able to.
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
Old Aug 26, 2001 | 06:34 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
If you had a strong running L98, a good solid tranny and 3:23 or 3:42 gears I'd say it's possible. Port the intake, plenum and runners, do some weight reduction, borrow some drag radials and skinnies, drop the front sway bar etc.
The only mods I had on my 13.81@98.96mph L98 motor was pulleys and adj FPR. I had a home made cold air, dropped the front sway bar etc. I did have some suspension mods that helped get me the 1.96 60ft.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Aug 26, 2001 | 09:53 PM
Iroc n roll's Avatar
If you can port the sh*t out of the heads and intake, drop anything not used for racing out of the car, hack off most of the exhaust, and put a quarter or two in the FPR then you got a shot at hitting 13's. And It'll only cost you $.50 if you have the tools . Oh yeah.... gaskets too. Bald *** tires would help too as long as they don't blow out on you. You won't be emissions legal, the car won't have a lot of luxuries (A/C, power steering, back seats ). Also bald tires suck in the rain (not to mention they're illegal) If you want to keep this car emissions legal and have it as a daily driver your probably going to have to spend a couple bucks to compensate for the weight and luxuries. But if you can port, do it, you'll probably see the most results there. If your going to put the pedal to the metal on this car or any F-body I'd lay down the cash for subframe connectors. Although they are some of the coolest looking cars ever made, these unibodies are ****ty. Everyone I know without 'em that hammers on the car has stress fractures, tweaked frames and popped T-Tops. Its worth the money IMHO. Sorry for the long post. Just my $.02
Old Aug 26, 2001 | 10:05 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by Iroc n roll:
If your going to put the pedal to the metal on this car or any F-body I'd lay down the cash for subframe connectors. Although they are some of the coolest looking cars ever made, these unibodies are ****ty. Everyone I know without 'em that hammers on the car has stress fractures, tweaked frames and popped T-Tops. Its worth the money IMHO. Sorry for the long post. Just my $.02</font>
Amen to that!!! SFC's are worth EVERY PENNY!!!
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Aug 26, 2001 | 11:15 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
<font face="Verdana, Arial" size="2"> (snip) ... and put a quarter or two in the FPR then you got a shot at hitting 13's. And It'll only cost you $.50</font>
use pennies to bump up the fuel pressure and save the $.48 difference for gaskets.
Home workshop cold air intake, increased fuel pressure, home ported intake. Sounds pretty good to me.
89 IROC with lots o' stuff
-=ICON Motorsports=-
Old Aug 27, 2001 | 02:01 AM
BahamutRS's Avatar
How do you adjust the fuel pressure with the stock pump?
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
Under drive pulleys
LT1 camshaft
Soon to be installed:
Edelbrock intake manifold
3.42 rear axle
B & M 2400 RPM stall torque converter
Transgo shift kit
Moroso Blue Max plug wires
305 TPI heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Old Aug 27, 2001 | 10:31 PM
<font face="Verdana, Arial" size="2">use pennies to bump up the fuel pressure and save the $.48 difference for gaskets.</font>
LOL...I guess if you really want to save pennies would do. I can't remember what monetary denomination actually fits in there but theres one that fits pretty nicely. Don't know if its a quarter or a penny but use the one that fits the best. To BahamutRS: That is how you bump up the fuel pressure. It doesn't matter if your fuel pump is stock or not. Fuel pressure is controlled by the Fuel Pressure Regulator (FPR). Its a little black cap looking thingy under the plenum with a vacuum line coming out of it. To bump up the fuel pressure you can replace it with an Adjustable Fuel Pressure Regulator (basically the stocker with a screw and metal disk), or just put some coins in the stocker. Each coin you put in bumps up pressure a few PSI, if you want to be exact get a gauge. And if you'll spend money on a gauge you can buy an AFPR or make one yourself. Just make sure that you relieve the fuel pressure in the system before you do any work to it. This is VERY important because fuel ignites easily and you won't want to have fuel pissing all over your garage if you have anything electrical near by.
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, Dropped Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Aug 28, 2001 | 10:31 AM
rondubbs's Avatar
our TPI's already run rich so i wouldnt bother with bumping up fuel pressure.
Old Aug 28, 2001 | 03:26 PM
evilho7810's Avatar
Take out your whole interior except drivers seat, break out the hole saw and go to work making the car look like swiss cheese then I gaurantee 13's with all the free mods done. Or you could always go mow the someone's lawn for a year and get some headers.
Old Aug 29, 2001 | 06:20 AM
Cam28_boy's Avatar
Last time I went to the track I recorded a 14.01@101mph. That's with only a few free mods, k&n's, cat-back exhaust (flowmasters), afpr(set at 50) and new goodyear gsa's on the back. I'm expecting to get no lower than a 13.7 when I go to the track in a couple of weeks.
Old Aug 29, 2001 | 11:47 AM
Cam28_boy's Avatar
I'm in the 13's with not to many expensive mods.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
