Egr?
Old Jun 4, 2005 | 04:07 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
Egr?
I here of alot of guys blocking off there egr on there tuned ports. Will this effect my computer in any way. I dont know of any way this will help performance other than keeping the hot gases from entering the system again. Thanks for any reply.
Doug
Old Jun 4, 2005 | 04:52 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Egr?
Originally posted by 355gta.I here of alot of guys blocking off there egr on there tuned ports. Will this effect my computer in any way. I dont know of any way this will help performance other than keeping the hot gases from entering the system again. Thanks for any reply.
Keep the EGR in-tact, as blocking it off will not net you that much of a difference in performance... not much to brag about, that is.
Old Jun 4, 2005 | 05:03 PM
355gta's Avatar
Engine: 355
Thanx for the advice. I am building a new motor and wanted to do the lt1 conversion that has the egr blocked and was not sure if it would send codes.
Old Jun 4, 2005 | 05:20 PM
Originally posted by 355gta.Thanx for the advice. I am building a new motor and wanted to do the lt1 conversion that has the egr blocked and was not sure if it would send codes.[
You'll need to disable the EGR's function in you're ECM.
Old Jun 4, 2005 | 05:37 PM
355gta's Avatar
Engine: 355
So, when i order my new prom i need to specify that?
Old Jun 4, 2005 | 06:05 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
whats the point though? it shouldn't effect performance any being that the car EGR shouldn't be active if your are giving it much gas.
only time it should be on and active is when cruising and from my understanding it helps out with giving you a little better gas mileage
Old Jun 4, 2005 | 07:53 PM
Originally posted by rx7speed....only time it should be on and active is when cruising.
Exactly, at WOT the EGR valve closes...
Old Jun 4, 2005 | 07:55 PM
Originally posted by 355gta.So, when i order my new prom i need to specify that?
If you decide on going with an LT1 intake, and/or a Holley Stealth Ram, yes...
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
