need help fast
Old Jun 5, 2005 | 03:03 PM
jksstar's Avatar
Car: 1985 IROC Z28 and 99 Nissan Altima
Engine: 305 TPI / KA24DE on N2O
need help fast
put in new crank and bearings (305) put all back together. when i go to torque the rod bolts to spec, crank will not turn(will not turn over)but, if i loosen them all, it will turn over. what could be the problem? all the bearings are matched for the crank so, it should not be the wrong size bearings.
any help would be appreciated
Old Jun 5, 2005 | 03:25 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Check your bearing clearances with plastigauge...probably wrong size bearings.
Old Jun 5, 2005 | 03:28 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
Did you put the caps back on in the same place.
Old Jun 5, 2005 | 03:42 PM
jksstar's Avatar
everything was checked before hand and I have no way to check now. All of the caps went back to the same places. But now after messing with it I can tq them all down now but the #4rod, as soon as I tq the #4 it will not turn any more. So I have it down to that one now,. I checked the rod bearings to make sure they were in right, and they look good, but it will not turn when I have it tight. anything more the 15pds of tq and it will not turn over???????????
Old Jun 7, 2005 | 12:41 AM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
u might have to re measure everything and ur crank might be bent
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
