Replacing TPS on a 86 Carb'd 305
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
How to replace TPS on a 86 Carb'd 305
Can anyone get me through this process of replacing my TPS on a 1986 Carb'd 305. It looks like this TPS for 1986 305 Carb engine I think it is in the carb? Help please.
Tony
Tony
Your TPS is located in the front driver's side of the carb. You should see the connector there with the aircleaner off. You will have to remove the top of the carb (air horn) to get to it and drop the new one in. You will probably have to remove some of the linkage to get the airhorn free enough to get to the TPS. I'd have to look at it to know what all for sure. Hope this helps.
