Oil Filter Adapter
Old Sep 2, 2001 | 07:14 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Oil Filter Adapter
I need to order the oil filter adapter for my new motor. I thought one would come with my oil cooler but it didn't. Do I just need to order the plate with the nipple and the two bolts??
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
Old Sep 2, 2001 | 08:43 PM
ede's Avatar
ede
the one for my oil cooler uses the threaded fitting the oil filter screws to to hold the adapter for the cooler. for the cooler adapter you'll need an inlet and outlet in the adapter. look in a permacool catalog or web site to get an idea of what's avaiable. gm also uses oil coolers on several differant cars and trucks. i know the 4.3 uses one that bolts up using the 2 bolts and has 2 tapped holes for the cooler lines.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 2, 2001 | 11:02 PM
Car: 89 IROC-Z
Engine: 383
I already have the cooler with the sandwich adapter. I just need the plate with the threads that the filter would go onto on a normal setup as well as the hardware.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
