305 to 350
Old Jun 9, 2005 | 01:06 PM
Fastcar92's Avatar
Car: 91 RS Camaro
Transmission: 5 Speed
Axle/Gears: 3:08
305 to 350
I bought a 92 rs camaro and im buying a 350 to put in it but im getting a bunch of different answers on I cant do it. now im sure 92 rs came with a 350, but even though Im putting a edelbrock TBI intake set up for the motor and I guess I have to upgrade the chip. what kind of headers can I get to fit that year and size of motor thats has the smog tubes? any other info would be nice. thank you!
Old Jun 9, 2005 | 01:21 PM
ede's Avatar
ede
try this if that doesn't work try posting on the correct board
Old Jun 10, 2005 | 07:16 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Make it easy on yourself... go with a carb.
If you want to keep your TBI it is a little tougher because 350s did not come stock in Camaros with TBI - they had TPI which is a whole different fuel injection system.
Either way, it CAN be done. I have a 92 RS that used to be a 305 TBI as well. Now it is a carbed 350.
Old Jun 10, 2005 | 09:20 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
camaro 92
ok with a 600 carb but what about the emissions I live in Calif. and what about the computer brain, do I have to change the wire harness?
Old Jun 10, 2005 | 09:36 AM
chesterfield's Avatar
Car: Pontiac
In CA you have two ways to go. Put a 350 in and disguise it as a LO3 and the smog guy won't know the difference or swap a92 or newer 350 from a passenger car complete with emmissions and computor and take it to a referee to get it approved.
Old Jun 10, 2005 | 11:29 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
camaro 92
what is a Lo3, and im buying a crate motor long block and edelbrock sells a tbi intake for that motor, I figuered I would have to just up the chip. I was asking if I went with a 600 carb would I have to change the wiring? thanks for your input
Old Jun 23, 2005 | 07:28 PM
glintscollide's Avatar
little changes to the fuel lines.Fuel regulator or a mechanical pump,and carb brackets for ur kickdown cable and throttle.I know thers a thread somwhere on tgo that tells bout this.I dunno but I wanna go carb to bypass all the computer crap.A lo3 is a 305 engine with the 700r4 automatic tranny"good lttle car."
Old Jun 23, 2005 | 09:23 PM
sellmanb's Avatar
Car: '86 Berlinetta
Any parts that you get will have to be CARB certified, otherwise the smog ***** will get you.
Your best bet is to just take your 350 and put the TBI system back on it. I believe you'll need a new ESC and knock sensor. Possibly a larger injector. You'll need to search in the TBI forum for complete swap info.
As for the headers, check out the stickies at the top of the page on the exhaust forum.
You'll need to have computer work done to your car for any mods that you do, since it's a TBI. And I dont believe you can legally "upgrade" to a carb in California. Even if it has a CARB number.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
