Speedometer help
Old Jun 10, 2005 | 01:40 PM
Ironmahn's Avatar
Car: 1986 Trans Am
Speedometer help
Hi all!! Looking for some help or places to get information. I have a 1986 Trans Am came out with TPI 305, but when I purchased it 350 carburated. Through the years of miscellaneous owners the wiring harness has been cut to pieces i.e. plugs for a/c, & sending units gone(cut off) etc. Okay, I installed a different carburated engine with a 350 transmission and want to get the factory electronic speedometer to work; never has worked since I have owned it. Thanks for any help. Cheers...
Old Jun 12, 2005 | 10:20 AM
Vader's Avatar
The VSS on a Pontiac is mounted at the transmission. Make sure it is connected to the speedometer, and that the VSS buffer module for the ECM isn't shorting the signal to the speedo head.
Old Jun 14, 2005 | 04:26 PM
andys86ta's Avatar
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
Check out http://www.hioutput.com/tech/speedo.html I am in the same situation. What did you mean by the ecm shorting to the speedo head?
Old Jun 16, 2005 | 01:47 PM
Ironmahn's Avatar
Car: 1986 Trans Am
Thanks for the link andys86ta.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
