head gaskets
Old Sep 3, 2001 | 06:27 AM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
head gaskets
hi, im haveing a problem unbolting the last screw on the exahast manifold on the passanger side near the firewall. i have an 89 trans am GTA 5.7L TPI. i have the intake off, and the valve covers. the A/C assembly seems to be blocking the last two screws though. i managed to get one off but the last one is impossible. i took the canister off, but that big "bump" on the firewall that is behind the canister is whats my problem. i cant seem to get the thing off. i took all the screws off and it seems there is still one or two more holding it on near the bottom. i have spent nearly 2 hours just looking for these hidden screws but i cant find them. if anyone here has valuable info on this problem i would really appreciate some help.
Old Sep 3, 2001 | 06:48 AM
ede's Avatar
ede
you shouldn't have any access problems with the correct tools, swivel socket, long handle wrench, wobble extensions, or flex head ratchets. you shouldn't be needing to remove any of the Ac related parts to get at the manifold bolts.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 3, 2001 | 06:55 AM
Psyte's Avatar
how do you figure? the a/c equipment is totaly in my way. i have alot of special tools for this kind of job and the thing is, there just isnt enough room to turn a wrench or rachet without removeing the A/C stuff. everyone else i have talked to has said the whole A/C set up has to be removed in order to remove the exahast manifold. the bolt is rusted on and i need to remove some stuff in order to put some muscle into it. there is just no room unless i remove the A/C. if its this hard to take it off i can just imagine how hard its gona be to put it back together...
Old Sep 3, 2001 | 10:33 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
hey man i've been there. to get to the last two bolts raise and support the vehicle and then get the bolts through the bottom. it will be much easier believe me.
88' IROC-Z, 350 TPI, 700-R4
Old Sep 3, 2001 | 10:53 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
actually its easiest when you disconnect the air tubes and get the last one with a 9/16 box end. I know a box end takes forever but its the only way I can get mine out.
good luck man I sympathize also.
Old Sep 4, 2001 | 06:35 AM
Psyte's Avatar
ok i got the last two bolts off. but i realize now that their is an extra set of head gasket screws right under the exahast runners. do i have to remove the bracket holding the a/c pump (that the belt goes around) in order to get the heads off? or is it a good idea? re-assembly is gona be real tough now that ive screwed with my a/c system. is there anything special that i have to do to remove the drivers side heads? and how much is a set of head gaskets and valve cover gaskets gona cost me in canadian dollars?
Old Sep 4, 2001 | 09:42 AM
AlexJH's Avatar
Engine: 5.7L V8
Ok, did you know that there is a certain order to remove cylinder head bolts to avoid warping the head? Well, removing them isn't too bad but you should definitely get a Haynes manual to tell you how to put them back on.
BTW, take your heads to Ron and Ron's machine shop to get the heads checked out. They're good guys.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
