Completely Removing the AC
I have removed most of the components of my AC. I removed the top half of the evaporator housing to get it out and left it off. What can I do to close this off? I've heard that the blower housing from a non AC car will bolt up and work. Will it work the same if I custom fabbed a flat plate to just bolt to the top? I think it would be a great place to mount an MSD box. Give me your opinions. Also I have yet to remove the condenser. Can it be removed without needing fabbing and/or other parts. How do I take it out? Take off the shroud and pull up?
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, Dropped Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to askulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
--Cullan Hooley
yup i ripped all that out of mine a month or so ago. amazing how easy it is to get at the header bolts now. you pull the top cover off and the condenser will slide right out. i took the whole box out of mine and now im in the process of looking for a non a/c heater box...among many other things.
my $.02
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
my $.02
I think you might have misread the post or I'm calling the wrong thing the condenser. I already took the thing in the firewall out. The one in front of the radiator is the one that I was talking about. But while we're at it. How did you get the rest of the box out too?
Ok, so I was right. Sorry for the confusion. So does anyone have opinions about blocking off the evaporator box in the firewall? Custom fab a plate to mount a MSD box or get the non AC blower cover from another car? And does the condeser come out easy?
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
DEFINATELY get a non-AC heater box. You won't believe the space you'll have after you put that on. You'll have plenty of room mounting an MSD box there with the smaller heater box. You can get one in West Hartford from a guy named Matt (860)983-4223. It's an f-body junkyard. I got mine from there, it was pretty rusty, but I got it sandblasted and painted it myself and now looks better than new! Good luck Ryan.
Terrell351
Jun 13, 2021 01:13 PM
